---> Get your Deco multigame Here <---
I already have one but may be up for a second just to have a spare or put with a second board set I have.
@Darksoft I am finally getting this tested after moving my place, and i found 3 of these -8 Systems :D
i think i was one of the original 5? or pre-5 ? not sure, been pretty long time, is there any updated Bios images i need to burn?
Well, no go :(
WIDEL.COM 3.0
DONGEL ERROR
Same error on both working cages..
:cursing: ;(
So, looks like i got this pretty early in the release... ( 11/27/2017 )
Confirmed Bios Chip & Game rom are 100% match to above posted and the one he posted in Troubleshooting..
I noticed my EEPROM was actually blank... I wonder if the Xilinx is blank too :(
WOOHOO! ok, checked voltage at Bios Chip, was 4.8V, bumped up the PSU to 5.1v @ bios rebooted and Bam! now working!
OK, problem solved.. Cold Solder Joint on the Dongle :D the 3.3v tab on the voltage regulator wasn't making good contact .
Too late to the party, but glad that you got it solved.
Yeah you gotta check behind Darksoft on his soldering. :P
I thought you did all the soldering :P he was just the design guy. i have had to do that a few times.. My CPS2 had soldering issues, and a few of my Naomi CF had soldering issues..
The first batch of DECO was soldered by DS. I soldered a second batch that hasn't ben sold because the programming is not done.
If any of that programming ever gets finished on the second batch consider one of those sold. I will keep waiting until it’s ready.
