Thank you for the info : )multi-bios should be no problem (except for the garbled startup screen which can be disabled)
No... Because no "multi-BIOS" exists for MVS.My board is running a multi-bios
You’re assuming multicart users will discard all their original carts and/or they won’t want to use any cheat code (both with original games and multicart).@Darksoft has stated at some future point the multi cart firmware itself will allow you to set the region.Making UniBIOS completely unnecessary for 100% of multi cart users (owners of the Chinese 161-in-1 cart will still want to retain UniBIOS for "pick'n mix" mode).
Correct, I was assuming that (because I basically did this myself).You’re assuming multicart users will discard all their original carts
Oh good point, I had not considered that feature at all.or they won’t want to use any cheat code
Yeah that’s what I meant. My MVS came with the UniBIOS already installed. Was just wondering if I needed to get an original BIOS chip or not to run the DS cart. If it works as is I’m just going to leave it in.No... Because no "multi-BIOS" exists for MVS.What you mean to type, I am running the "UniBIOS" (made by Razoola).My board is running a multi-bios
Its fine to just leave it in.If it works as is I’m just going to leave it in.
Both features which have nothing to do on a cabWith the UniBIOS I like being able to hit the coin button on my stick plus start to pause games in arcade mode (this brings up the cheat screen, but I use it for pausing lol).
Aiko just found this by the trash the other day. Not sure how much work it needs to be operational again, but I’m thinking of building a case for it and adding it my supergun setup. She named it “Oscar”Both features which have nothing to do on a cab Coining up is part of the experience bro!With the UniBIOS I like being able to hit the coin button on my stick plus start to pause games in arcade mode (this brings up the cheat screen, but I use it for pausing lol).
