Exactly my thought with this Irritating Maze kitStep 1 - connect it so it works
Step 2 - I have no f-ing idea what to do with it after that
You need help with an irritating maze kit? I've got one.Exactly my thought with this Irritating Maze kit
I have a complete kit EXCEPT for the trackball, still looking at my options for that. but I even got the air compressor/flasher relay board from the upright version and figured out all the wiring. At some point I'd like to make a custom panel that includes the air-blast and strobe lights.it would have been easy to put the trackball in a CP somehow
yup, gotta spend some time on that Rave Racer cab you got!It's in the garage waiting for you
I'm assuming it expects the sensor line to go low for x number of seconds? I wonder if that's something that could be simulated on hardware with a cheap 555 timer. or is this something that could be disabled in game options?besides trackball this game require hopper (simulation) - when motor line active game expects sensor line will toggle.
that's good. that just means it's likely a simple switch.In the schematic I see there is a 'hopper check' line at Jamma connector 'a' (2p B2)
would it pull it to GND or to 5v you think?that's good. that just means it's likely a simple switch.In the schematic I see there is a 'hopper check' line at Jamma connector 'a' (2p B2)
