I have a dedicated Taito TypeX setup for Tetris and it works great, but it's a pain to move around. I wanted to see if something more portable could be made, like consolization projects.
Can you help me think out the project? Or make hardware suggestions?
Thank you for your input!
- Above all, must avoid input lag. This is why I use real Sega I/O and not loader.
- Needs accessible COM port, either pins on motherboard or RS232, to connect Sega I/O board. No USB to serial allowed!
- GPU speed must be greater than or equal to Taito Type X, run with no stutter. Not sure how to measure needs of this game with mobile GPU.
- GPU needs analogue video output (NTSC composite or s-video). I only use CRT to avoid lag.
- Original uses Windows XP. Is it okay to use newer OS?
- Laptop or small form factor, maybe Mini/micro/nano-ITX board?
- All hardware must fit in one project box with two DB15 ports, one power, analogue video. If laptop, separate box maybe OK.
- Does newer Windows OS and Type X game cause problems? Since Sega I/O uses serial connection, maybe not an input lag problem.
- Drivers are difficult to find for XP, more if XP SP2 or earlier.
