Hello,
I have come to the point today that either using the most common jamma extenders or putting the supergun or the jammafier directly to the pcb both solutions are so fragile when it comes to change often PCBS.
- Jamma cable : loss of voltage, loose pins, solder going bad
- Straight to the connecter : plastic enclosure can break when trying to put out the pcb with left/right movement, pcb solder can break also when it's not perfectly aligned
Today I came to the conclusion I need a strong quality built jamma extender cased on both sides with the right cable gauge, and good quality pins.
Is there such a product available ?
Thanks
UPDATE 20181221 : Here are the parts to order :
IDC Connectors
IDC Sockets
Ribbon Cable
24 Pin Female Socket
30CM ATX Cable
Thanks
IDC Connectors
IDC Sockets
Ribbon Cable
30CM ATX Cable
