InfiniKey-CPS2
    • undamned wrote:
      zerox_dogma wrote:
      I need buy some infinikeys but are out stock.
      Where I can buy 5 infinikey . I wrote undamned but never received answers.
      Patience, sir :) Was that you that wrote looking also for CPS1 InfiniKey? If so, that is the reason for delay.
      Paradise should re-stocking soon. I'm just waiting for payment before I ship out.
      -ud
      Excellent. Thanks
    • undamned wrote:
      parodius wrote:
      I thought I read somewhere that the resistor you can find attached to the pins of cn2 on some rev 3/4 boards was there to help with key programming.
      Some Rev.3/4 have a pull-down resistor on the clock signal to lessen the chance of bogus bits getting written, but after loads of testing, I never found it necessary (for InfiniKey, at least). Konosuke's CPicS2 adds a series resistor to one of the programming signals, but I don't know which signal or if it would even help in this Asia board situation.-ud
      So your advice would be to just leave the resistor off? Found one in a rev 4.
      Edit: Nevermind, you call it out in your install video, so I'll take it off as well :)
      The post was edited 1 time, last by Sp33dFr34k ().
    • I'm having a problem with an Infinikey and a grey B board running Street Fighter Zero 2 (960227 ASIA)
      I'll first say that I've installed a few Infinikeys over the past few months but this is the first one that's given me a problem.
      The B board rev is 93646B-7
      From checking progettoemma.net the MAME name for this code is SFZ2N - in the Infinikey Game Select file this refers to SZ2N
      So I set the jumpers accordingly by bridging the required pads - (numbered from 7 to 0) - 1010110
      I then removed the battery from the B board - I should say that before I removed the battery the game was working just fine.
      After removing the battery I shorted the three pins for EXC1 as I always do.
      I then installed the Infinikey to the rear of the board (CN9, orientation was correct, etc), plugged in the B board and got a slightly out of sync blank display. I re-checked the Infinikey instructions and realised that I had forgotten to jumper the pad for 'open for 93646B-5' - so I jumpered that. Powered on again - the sync was then stable but still a black screen.
      Checked everything again a few times and am now stumped.
      Any ideas please what could be wrong? I've had a long day and am a bit tired so maybe I've missed something obvious.
      EDIT: Forget all of the above, it was my mistake. As noted, I obtained the version of the game by looking at progettoemma.net - this stated that the MAME name was SFZ2N. That's wrong as I discovered when running ROMIdent on a dump of program EPROM 3 - the ROMIdent name is SFZ2A. Once I set the jumpers for that on the Infinikey the board booted just fine.
      My apologies. Did I say I was tired? :)
      The post was edited 2 times, last by VectorGlow ().
    • @undamned
      So, I'm trying to remove an InfiniKey (Mobo Rev.7 install) for a Darksoft CPS2 install, but try as I might I straight up can't remove the thing. How far do I have to go to fully disable the InfiniKey so a Darksoft CPS2 install will work? I would like to remove as few components as possible from it in case it gets reused on this board in the future.
      Edit: I worked it out and got it removed. Went about it wrong from the start. I should have kept adding solder and turn it into one big molten mess instead of trying to remove the solder.
      The post was edited 4 times, last by Rotanibor ().
    • Have a weird issue with a X-Men Cota. I installed infinikey's in other boards and they work fine. This particular board though is a mess. It'll work, then green screen when I power it. I removed EXC1 & EXC5 completely. I took off the electrolytic cap and then soldered it back in.
      This particular Infinikey I soldered to much with and set aside, I have a better soldering iron and solder now.. Maybe I damaged it? I am using the other side of it with this install. Here is a picture of it. Any clue what this could be? Picture does not show the removed EXC1 & EXC5.
      Images
