No, still 0x456.Menu is the same as November 22nd. It won't change. The Firmware is different. Does it say 0x457 now?
were the files deleted from \update? All of them?No, still 0x456.Menu is the same as November 22nd. It won't change. The Firmware is different. Does it say 0x457 now?
I tried to update one more time and nothing changed!
Yes, all of them.were the files deleted from \update? All of them?No, still 0x456.I tried to update one more time and nothing changed!Menu is the same as November 22nd. It won't change. The Firmware is different. Does it say 0x457 now?
So this always happened to you with all versions, right? Which PSU do you have? I'm afraid that the problem comes from there.Hi,
I updated to the last Firmware and since, I also have small glitches and/or lines on some games.
For exemple, there are small lines on the SNK logo in Garou and a few glitches during gameplay.
I have an early NEO-0 model (SN 018051), stock BIOS and stock power supply.
Yes, the glitches that I mention in "AES Multi Cart Troubleshooting and help"@Samy83 Yes, you're right. The version r1111 will show in the menu still as the r1110.
So what issues do you have? Are these the glitches that you mention here: AES Multi Cart Troubleshooting and help
That's because I forgot to update the number on the flash.img file.But why it say 0x456 after update?
The cart is more power hungry and also needs a more steady power.glitches are not present with my original games but they are when I play the same games with the multicart.
I recomend this one: https://retrogamesupply.com/collections/neo-geo/products/power-supply-for-snk-neo-geo-aeswhich one do you recommand to replace my old one?
Ok, thanks. I will buy one they the model for my console (Pro-Pow) will be back in stock.I recomend this one: https://retrogamesupply.com/collections/neo-geo/products/power-supply-for-snk-neo-geo-aesThey ship from France, so you should be good.which one do you recommand to replace my old one?
Without using unibios options, it works well
Can you confirm that the games work well without UNIBIOS and the latest Firmware released?My problems of unibios is always the same; But note with every games.
Did that version work well for you?Shall i have to change with the top file of the update 20190829_r1075?
With new update and top file 20190829_r1075 everything is ok except using unibios option.Did that version work well for you?Shall i have to change with the top file of the update 20190829_r1075?
