BilonFullHDemon
I see you placed an order. I'll print the purple one instead of light grayBlue and green enclosure already sold out![]()
Worth the Wait!After a long break, I've finally reopened the store!
The HAS is now available with a proper enclosure in three colorways. Printed at a 0.1mm layer height to minimize visible 3D printing lines (each case takes +3hrs to print).
Stock is limited this time, so grab yours while it lasts - https://rgbslab.com/
Thank you!
Green/black would look slick. Too bad my 3D printer will be busy for a while now.. but I'll print this combinationwhat about green and black like jp cps2 though?
finally got those 3 jamma extender I needed.
gotta admit those psu kits and HAS cases are pretty slick, maybe another time![]()
Red? I didn't see Red. I WANT RED!This case is lovely. Feels so good in the hand protected like this. Sturdy like a NES cart. Would make transporting it a breeze!
The risk of static charge buildup is about the same as with the acrylic plexiglass case. Both can build a small charge if you rub them against something like fabric, which I wouldn’t recommend@RGB I have a question regarding ESD safety regarding these enclosures. I am assuming these are printed in PLA or Nylon which are insulators by nature, will this not cause an issue regarding ESD ? (I have limited knowledge of electronics so please forgive if I am missing anything obvious here)
Hi, I have an odd question, is the case designed to match hight of an PCB on standard arcade PCB feet?
Thank you!No, you will need some sort of support underneath the HAS if your PCB is on standard height feet.
