Baby's First Candy Cab - OK Baby Restoration
Papapishu
New York City, Baby
Hello gamers,
You may have seen this listing from @YubiParts, who imported a bunch of OK Babies and Astro Cities as project cabs in various states of repair. I decided to bite the bullet along with the thread and buy one, in part because I write about this stuff for a living, I had already recapped a CRT, and it was a thinly veiled excuse to write about the process of repairing a cab. I posted about it for the site I blog for/co-own cooperatively – Aftermath.
On another OK Baby thread someone encouraged me to start a thread where I document the process.
Here's where this thing is at: I have not turned it on except when we initially checked it out before buying. I wanna restore the shell first and work my way inward to the electronics. Here are my current plans for the baby.
1. Cleaning the shit out of it.
I did an initial pass when I got it home, but this thing needs a deep internal cleaning and I can only do that when I get the monitor out, which I want another person for. Already hit it with Simple Green but I may do a round with Purple Power.
2. The Power Supply Needs Replacing
One thing I know about this cab is that the PSU was acting funky, and frankly I would rather just put a new one in there. I have had great success with Meanwell in basically every other project I have used it in (particularly LED lighting, they are the budget PSU pick for basically every hobbyist project) so the list in SmokeMonster’s thread seems like a good place to start.
2. Redoing the shell – sanding, resurfacing and painting/vinyl dye
Initially I assumed that these things were yellow because they were in a smoke filled arcade, but what I figured out later is that this entire thing appears to be ABS plastic. Retr0briting, though effective, would be very cumbersome and apparently is not a permanent fix. Others have spray painted their babies with success. I have used Novus 3-2-1, and I will probably use this to prep the plastic before any major change in color.
But what I really want to investigate is Vinyl Dye. This Boarderstown thread and Twistedsymphony’s Taito Egret restoration thread seem to suggest this is a potentially good process for the baby, and I know that the cab comes apart fairly easily. That also just seems better for anything that could potentially experience physical stress.
3. Rewiring, new buttons, mod the stick.
The buttons on this thing have seen a lot of abuse, and so I am going to replace them. Seeing as I have a ton of keyboard parts in my house anyway, I will probably go with seimitsu alutimos. For the sticks, a new actuator and some Sanwa JLF Violets. Even if I kept the buttons I would have to redo the harness either way because this thing was not soldered well at all.
4. Fix the CPO, new decals
In addition to the buttons being mushy from years of abuse, the area around the sticks are rusted. I have some reproduction decals of the OK Baby coming on the way already from @joeks (I believe that's their name on here at least). Getting rid of that rust, repassivating, painting, and applying a new CPO is going to be a must.
5. Plastic welding or something similar.
A lot of the Babies were reinforced with external braces where the control panel met the body of the cabinet. This is an understandable stress point, as people would regularly sit on these things like idiots, causing it to flex and break. Mine has one of these ugly external braces, as well as a pretty substantial crack. This needs to either be plastic welded, or sealed using JB Plastic Weld. Maybe a bit of bondo or some kind of filler that works like plastic would be appropriate.
6. Replacing the monitor handle.
The baby has two handles that are used to remove the monitor, potentially for putting it in TATE. I don’t think there is a way to safely create a rotating mechanism for this due to the clearance on the kickstand, but one of the handles broke so finding a replacement should be a priority. Someone suggested a handle meant for an amplifier as a place to investigate. I will measure the holes and figure out if there’s an easy drop in replacement I can get at the hardware store..
6. Figuring out the monitor’s whole deal. See how the speakers hold up. Make plans accordingly.
I have not pulled the monitor out of this since I got it, but I have poked around there a bit with a flashlight. The tube seems to be some generic Chinese or Taiwanese tube I don’t recognize. My best guess is it’s a dual sync board. Once the PSU has been tested I will test the monitor out extensively and swap the tube if need be. If that happens I may just look for a Nanao MS29XX, because I would love to have this thing work at 31 khz for Naomi and even PC core stuff. If there is a comprehensive list of 15/24/31 compatible models, I’d love to see it.
7. MiSTerCade
No brainer, although I may also put a Naomi in there down the line. One of these days I hope someone does a core of the board that Osman/ Canon Dancer is on because I would love to have that running natively. I think a busted Joe and Mac Returns/Magical Drop donor PCB would be needed.
A friend of a friend has some spare tester boards so asking him to help out.
8. I guess play video games on it?
Is that legal?
9. Get a hat made.
I love the OK Baby logo, so if someone has a good SVG of that handy I can get a bunch made.
Anyway those are my plans. I am sure it will take ages. If anyone has any tips or is in the greater NYC area feel free to chime in.
I just recently took my ok baby cab apart to give it a deep clean (power wash). All I got to say is get ready for some major soot lol. If you need help with the electronics side of the restore hit me up because I basically rewired the entire cabinet myself... Good luck!
I may do that! The bottom part and electrical parts are a mess right now. A friend of mine who also got a baby actually made an outlet for the electronics.
I nearly finished with my ok baby so I’ll bite. I rewired the cab as well. Making the harnesses was super time consuming but it had to be done.
I also replaced the chassis, PSU, and the iso transformer. I tried to reuse the existing iso but it made the picture look horrible.
- Meanwell RT-65A
- Triad ISO Transformer
- universal chassis off aliexpress
The universal chassis was a drop in replacement which was a relief. Especially for the cost.
I’m stumped on this part of the electrical: There’s some interference in the video signal. It’s visible on dark images. Bridging the grounds didn’t change the picture. Disconnecting earth ground also didn’t change anything (just as a test, trying not to defeat earth ground.
It’s AC -> terminal block to two paths
Path A: -> ISO -> monitor
Path B -> meanwell -> Jamma + LED strip + mini audio amp
I don’t have the same symptoms on a buck converter + cheap 12v brick with the video hooked up to a PVM. There’s something I’m missing in my understanding of analog electronics to resolve this.
The video wires I snipped off the original harness. All other wires I ran new. Maybe the video wires needs shielding?
More pics:
I recorded a video but YT made it a Short and compressed it. I’ll reshoot and reupload on desktop
View: https://youtube.com/shorts/BozVzL4cRYk?si=fAqQzfWB2Wpod8Ys
To me it looks like you're missing an emi filter. You typically see the filter connected between your power cable and the isolation transformer. From my basic understanding if I understand correctly. The emi filters the ac current so you don't have ripples on the screen like that. My next guess would be shielded cables, but I don't think that's the case in this point
EMI filter didn’t change anything. Next time I’m in there I’ll ground everything per that diagram.
I also ordered another EMI filter.
Interference resolved!!
Kept EMI filter in because why not. I didn’t ground every device but this time I tied the grounds with a very short but large gauge wire. Admittedly I was using a thin long wire as a quick test before.
The idea to tie the grounds came from the Midway KI manuals. The idea for a thicker wire came from 7:55 here:
View: https://youtu.be/GS-6jBk9YPM?si=fstyBRYaa78qU0wW
I’m no electrician and I won’t pretend like I know why it works; it’s resolved!!
@Papapishu apologies for hijacking this thread for a bit. Hopefully it can prove useful
Hey! If it works it works lol glad that you could get everything working!
Oh no worries I’m actually taking notes for this right now.
I should have a chassis on the way but that’s TBD. I also need to figure out which color vinyl dye best matches a classic candy cab color. I’m guessing Dupli-color medium gray but that might be a shade too dark.
Edit:
Oh this guy seems interesting for paint selection although I think Acetone might be too aggressive for the cab.
View: https://youtu.be/c9WJipydQbo?si=wrIdEB_yz6PZSoLh
Did you have any luck with finding a paint you liked? There is an OK Baby near me for a screaming good deal, but it is badly discolored, so I was looking for a solution. Any tips would be great. Thanks!
Kinda took a break because it was winter and then taxes kicked my ass before I could buy parts. But I have a can of the SEM vinyl dye in white that I’m planning on testing out.
Also finally got the vinyl decals so I plan on starting to fix the control panel.
you have inspired to pick that one up. I was mostly worried about not being able to fix the yellowing, so I am appreciating the advice. By the way, were you happy with the way the decals came out?
Also whats up on a hat? Where can I buy one?! Hahaha
I need to find a good SVG of the logo, I think someone on here has one? I can try to ask the guy I got the decal from but understand if that’s technically original art.
Also the Decals came out great! Really happy. I need to remove the control panel and go at it with barkeepers buddy/sandpaper to fix the steel. Still need to buy replacement parts for this!
Use some real gloves when sanding away the rust on the panel. I got an acute infection near my fingernail after stubbornly sanding it down with my nitrile gloves. Long since recovered but still
Feel free to use mine https://www.arcade-projects.com/threads/weche-ok-baby-side-art.31992/
For rusty metal, throw it in a bucket of evaporust and come back a day later. It'll easily flake off with a wire brush. If you want it really smooth after, you can flap disk it.
