Yeah that would be DVP-5004GLast version is IMO the one that goes with DVP-5004
I was just wondering if there was a later revision known.
Error 28 is displayed when SEGABOOT is unable to verify the alpha-DVD. ie. it knows you are using a copy.
You have 2 choices:
1) Obtain an original install DVD;
2) Patch Segaboot to not care about the alpha checks.
I've never seen that G IIRC. I think I saw once a 5004DYeah that would be DVP-5004G
It exists, we have it dumped.I've never seen that G IIRC. I think I saw once a 5004D
Good info. What was added in that version G from the picture?
- Version A (Dec 2008 ): Improved game systems and added "Bingo Festival" support.
- Version B (May 2009 ): Changed character move animations, added balance tweaks, and updated the camera system.
- Version C (Nov 2009 ): Added new character customization items.
I don't think the DVD letter is the same as the game revision, I would think the disk with the bigger letter would be the revision C of the game.Good info. What was added in that version G from the picture?
The disks are marked as follows with version numbers, but i dont think it reflects the in game version number. I know for sure it doesnt on some games.I don't think the DVD letter is the same as the game revision, I would think the disk with the bigger letter would be the revision C of the game.
Wow! Is this for real?I made lindberg-keytool to recover previously undumped security keys without requiring decapping.
I'm happy to provide the service for free if you cover the shipping costs to and from France !
Using it, I successfully dumped the security key for After Burner Climax SDX ( 317-0463-com - 253-5508-0463 )
yes, and it's been working quite reliably so farWow! Is this for real?
From what I've seen the DVD is the same but has different sessions depending on what keychip is inserted, it installs one thing or the other.Hello,
Question about the DVP-5016 dump, SBTZ, World Club Champion Football: Intercontinental Clubs 2009-2010
Is this just the satellite software, or does it also include the server software?
If it's only the satellite software, where can I find the corresponding server software?
Thank you very much!
Server is on the same disk, but you will need the keychip for the server to decrypt it. As darksoft mentioned.Hello,
Thanks for the reply.
As I mentioned above, I have a working system with 4 satellites. It runs WCCF 2005/06, which is the latest NAOMI 2 version. The versions from 06/07 through 09/10 ran on Lindbergh.
I’d like to update my installation to 09/10, which means updating the hardware to Lindbergh (a minor issue) and installing version 09/10 (a bigger issue).
I see two hurdles here:
- Unfortunately, I don’t have a Keychip and wouldn’t know where to buy one
- Starting from Lindbergh, the server apparently ran on ALL.Net
My question:
Is it possible to make the game keychip-free (decrypted boot) and to “emulate” ALL.Net locally?
Thanks in advance.
