A Freeware Taito TypeX Multigame
The file was just a link to archive, it has been released.
Multi works well, but there is a resolution problem in games. How can this be fixed?
Hello. I have a problem that it says "error, unable to access drive d:"
Any clue whats happening? It was working good till yesterday.
It looks like your disk has become corrupted.
Can you see all your disks if you connect your drive to a PC ?
Thank you. for the details. I find this strange, the Windows partition should be write only so all changes done to the filesystem should be reverted at next bootup but sometimes the mount of drive D: fails.
I burned everything again and was working but after i put the autoboot feature on tetris tgm3, im getting the same error.
Is there anything wrong with this game in particular?
If i connect it to my normal pc is mounting all the partitions and everything seems good and normal.
Last night I created a new TypeX disk image based on a later game. This version has been running stable and features version 4.9.1 of the ttxshell.
I have tested autoboot and it is working as it should.
I still consider it beta so the background is red.
Here is a clean image, you will need to add the game files yourself.
https://we.tl/t-K3TwkCZA5P
The file is available for 3 days.
If you run into issues please enable debug like outlined below.
Code:
4.9.1 : Added more debug
4.8.4 : Simplified mount code
        Added retry if opening of COM2 fails
4.8.3 : Added more logging
4.8.2 : Added logging mechanism.
        If e:\ttxshell.txt exists the program log will be appended to this file.
        All log entries will be appended to the existing file
4.8.1 : Refactored all disk mounting
4.7.3 : adjusted delay in JVS addressing
        increased waitlength for d:\ to become ready
        [debug]
            Hitting enter on an error message will invoke: cmd.exe
I'm just back from holiday... sorry i missed the window!
Gigawing génération have fps slowdown in demo and in games.
I continues the tests.
