On the original TypeX there is a firewall in place which blocks the inbound port.Any chance you could incorporate an FTP server in the multigame GUI? It'd make file transfers a lot easier.
Cheers.![]()
LOL I knew I was forgetting something! Its since been fixed and i updated the post and will be adding link to the update package on the first page.Good news: 2-player controls workIf someone who has two player controls wants to test and let me know that it works I'd appreciate it.
Bad News: 2-player buttons are reversed![]()
Since this project has turned out so awesome I'm moving it to the Project Showcase and Sticky-ing it.
An FTP server would be a ton of work, It would be much easier to setup shared folders. However I have another project idea that was going to use the NIC on the X2Any chance you could incorporate an FTP server in the multigame GUI? It'd make file transfers a lot easier.
Cheers.![]()
, that took a bit longer to solve.Yeah I can do that later, but I would prefer a genuine HDD disk to look at the original files and this was on TTX not TTX2@rtw are you able to upload the dlls you used somewhere for others to use
Yep, it will probably be around the time v1.1 comes outAny idea if "notNiko" will release another torrent dump with the full game list added?
Thanks again for testing all those drives. I'll try this 169.21 driver when I get home.Tested a LOT of different graphics drivers. Everything in my previous list that was available on the Elsa site causes issues with earlier X2 games (e.g. BlazBlue series).
Ended up going back further thanks to the Guru3D archive and found ver169.21:
http://downloads.guru3d.com/ForceWare-XP-169.21-(32-bit)-WHQL-download-1800.html
TGM3 works (as long as you've added the missing DLLs to its folder), as do the BlazBlue titles, Battle Fantasia, Sam Sho Sen, KOF XIII, SF4AE2012, etc.
There might be some minor issues I haven't seen, but it seems the best driver for maximum compatibility will be greater than or equal to ver169.21 and less than ver191.07.
I'm pretty burned out after testing a crap load of drivers, so I'm going to stick with 169.21 for now unless I encounter any issues.
Thanks for confirming this Kuze...Tested a LOT of different graphics drivers. Everything in my previous list that was available on the Elsa site causes issues with earlier X2 games (e.g. BlazBlue series).
