thanks Dakken, pin 4 and 8 is the kick for both players.
In the middle the latest i/o board, I cant find the 3 kick button for both 1 and 2 players
Note all of this i/o has came from the ssf4 ae cab
The red one it has 5 buttons working in both 1 and 2 players I cannot find the 6 button in the red board
Help please guys
here it is I have 5 of this new i/o
That I/O looks like a copy of a CAPCOM I/O :?:
Could you take some hi-res pictures and share them with us ?
Also what does it identify as in the NAOMI JVS info screen ?
Looks like a Capcom without a case, volume pot, test button etc., everything in the correct position.
But no 'Capcom' written on the PCB anywhere?
It's missing 2 switches as well and the orange inductors.
http://wiki.arcadeotaku.com/w/JVS
I think it's a clone, this is why I want to see the JVS ID string and better pictures.
Now you mention it, it's missing the C/HV sync switch and the 2p6b/4p switch ;)
So it's a cheap clone then.
@ArcSys101, if you connect this to a NAOMI can you see all buttons ?
And can we get a hires picture of the red one as well, the entire PCB ?
this clone I dont know where is the 6th button or 3kick button for ssf4 ae
Do you know where can I hook it
Ok heres the pic of the Korean I/o
in the green sega i/o clone no I cannot find the 3 kick buttons
The red one korean i/o has 5 buttons in ssf4 ae, only the roundhouse kick in both 1 and 2 players are missing
Do you have a NAOMI ? If so connect a test harness to each one and manually toggle inputs, you can do that with DuPont cables or with a logic probe with a pulse function.
The Korean one looks like it has 5 inputs on the JAMMA edge and I guess the rest are in the small molex connector on the side.
heres my i/o I bought from japan and it from i/o in sega naomi tgey remove the cover this was a ton of i/o stocks from naomi, it has no molex outlet
, time harvest i/o has no voltage protection I just used the old pic from them
