Niko
I'm not really sure what your asking, Can you run the multi on a 204A X2? Yes it should work, but if its having problems due to bulging caps, you will still have problems. The only game that I know of that has issues with motherboards prior to 208A is KOFXIII, which I suspect can be fixed with a BIOS update but havent tested it.Hey mates. I hate to derail the conversation but have another question regarding the TX2 multi. I got a Chase HQ2 that runs on the older revision of the X2, the 204A. I swapped the video card for the one from my working X2 since Chase HQ2 uses the Radeon one. The system takes several tries to boot because of bulging caps but when it finally did I got a hal.dll error: "Please re-install a copy of the above file". Has anybody tried the multi with a Chase HQ2 X2 board?
Thanks,
\o/.k.
That is correct, you do not need the RFID card reader to use the FastIO board.I didn't know thatv1.4 does support FastIO, though I've never tested with one of those FastIO boards.good to know
I take it the card reader isn't needed if you're using a DMAC/fast IO combo, correct?
