japanese arcade otaku
Hello to all fellow arcade board users.
My DIMM has 256MB of built-in memory and BIOS version 3.17. Yesterday, an additional 256MB stick I bought from an online shop arrived, so I installed it into memory slot 2.
However, after inserting the new memory, the NAOMI system refused to boot up entirely—there was no video output and not even a boot-up sound.
I suspected issues such as poor contact between the cartridge and motherboard, loose internal DIMM connectors, or cracked solder joints within the DIMM unit. I should mention that the NAOMI system boots up without any problems when the DIMM unit is removed.
I tried visually inspecting the solder joints, reseating the connectors, and cleaning the connectors multiple times, but nothing worked; there didn't seem to be any physical hardware failure.
After spending over six hours on this, I was ready to give up and sell the DIMM unit online.
Then, I remembered something: this strange issue had started right after I swapped the memory.
I removed the stick from slot 2 and turned the power back on. To my surprise, the system booted up successfully, and the DIMM check passed without issues.
Thinking the newly purchased memory might be defective, I swapped the memory in slot 1 with the new stick.
Surprisingly, the system booted up and passed the DIMM check perfectly; the memory appeared to be functional.
I then inserted the original memory stick into slot 2 and turned the power on again, but the system failed to boot entirely, leaving me with a black screen.
It seems my DIMM unit prevents the system from booting at all if memory sticks are inserted into both slots 1 and 2.
I couldn't find any information about this specific problem online, so I decided to share my experience here.
I plan to buy a 512MB memory module to test further, though that likely won't happen for a while. Please forgive any awkward phrasing, as I am using Google Translate.
I would appreciate it if anyone who knows how to solve this problem could reply.
