Astro City - Gold, Garbage, or non-existent? Let's Find out!
God almighty, it is finally done.
Friday and Saturday were the final touches.
Got the surround and billboards installed. The surround is the one piece I didn't do much with beyond a polish. I may bondo it and repaint... but I also have my eye on YAJ.
I used some pictures from before paint to place all the cable ties where they were from the factory. I wish I could've found the same beige that Sega used, but these black ones will do just fine.
Some testing! This was after swapping around PSUs. The whole story is this: A few months back, I purchased a PSU and Amp from YAJ which I set aside for this cab. I recapped the PSu and Amp and then did some small testing with them, but didn't use them extensively. The PSU that came in the cab was actually in OK shape, so I recapped it and immediately put it into my other Astro. I've been using that one for a few months now.
When I started up the power supply (nothing connected, of course) I noticed a small buzzing noise. I checked all the voltages and everything was fine except for -5v. I tried replacing IC3 and the buzzing persisted and the -5v didn't change. The buzzing seems to be going from L2 (the large inductor). I have bid on a new PSU on YAJ in hopes that I can win it and harvest the inductor. That said; the PSU works ok. It's currently in my other Astro and running a MiSTerCade. I figure if it blows up I'd rather lose a MiSTerCade than a board that isn't currently being made.
After I swapped the good PSU into the new-er cab, I tested and it was working great!
Finally.... my arcade is READY!
What a fucking JOURNEY this has been. I really didn't expect to sink as much money into this (or time) as I did; but I'm really happy with the end result. I did the best I could to keep things as close to original as I could (stickers are on the way, by the way!) and I think it came out great. I will be posting a long-format video of my entire re-build sometime this week. I have 160 videos to organize and edit into a video out of clips I took while I put the machine together. I detailed every piece of it. I hope that this helps others out as much as the community has helped me!
A lot of people made this result possible, and there are likely people I'll miss here so I apologize if I miss ya!
@GeekMan1222 @ShootTheCore @FluxChiller @Softdrink @hursit @Lemony Vengeance @misteraddons @Ajax @kyletwentytwo @imbord3rlin3 @alberto1225 @AlxUnderBase @djsheep @hyp36rmax @joeks @opt2not @Aurich... the list very likely goes on. Thank you to everyone that has helped me reach my goal here.
I may restore another cab one of these days; but that was a metric shit-ton of work. For now, I'm just gonna play some damn games!
Amazing work. Thanks for sharing by the way!
Just posting to congratulate on the great job you did and to thank you for documenting it so thoroughly. This thread and the video are an invaluable help to all of those who are going to restore an AC.
Thanks Pedro. I'm glad to hear it's helpful! That was the goal :)
I saw you asked these questions:
what did you use to make iron parts (the “golden ones”) so shiny?-where can I found those green wires for grounding?
I'll answer them later on YouTube; but for now:
The pieces were re-plated. Most metals get zinc plated to help protect them from corrosion. I found a local plating shop and have them do yellow zinc on the yellow pieces and regular zinc on the silver ones. It requires that they strip the original and then plate them again. Electroplating can be done at home; but it uses chemicals that need to be disposed of responsibly.
For the grounding wires, I used some wire I found on digikey.com. I believe the circular connectors are on one of my first posts. The wire itself is just standard 18 awg copper stranded wire.
