Uh oh... Now this just happened on JAMMA via SCART RGB cable... Getting a green hue.
NOTE: I do get audio. I also havev the Component cable, which does not work at all.
It was working perfectly fine as you can see
For the sake of testing my CPS3 board, I tested with several others with the same green screen with CCBOX. Tested those same boards with my Arcade cabs which work perfectly fine. Any ideas?
OK Tested with another RetroTINK5X.... It's working! As I Swapped back to the other RetroTINK5X that too works again. I guess I had to cold reset. Probably due to the experimental firmware. NOT THE JJ-CBOX.
Still have an issue with JVS though lol.
