Axun Workshop - Supergun-MINI
was able to find this on the official website, looks like supergun does the conversion
they put a sticker on top of the power supply, here is the original one: Unless they modified the insides of the power supply which I doubt considering the note on their website.
I know. I have an original as well. I use it for CPS2 with minigun supergun.
Logically, there is no reason to put that sticker there and assign -5v in the diagram to that pin unless it has been modified.
I tested that power supply when I repurposed it (because I did not find it adequate for my use case) and it outputs -5v.
good stuff, do you have the pinout for the cables by any chance, I have the same powersupply and I stripped the cables and will wire it for HAS.
Edit: Here it is :
Cable ColorVoltage output
WhiteGND
Green-5V
Blue+5V
Red+12V
YellowGND
none - bare cableGround
White
Green
Blue
Red
Yellow
I did not write it down and they are all under heat shrink now.
It should be easy enough to test with a volt meter.
