santashiva
I’m so impatient to receive mine
since the time i wanted to test evolution soccer
hi :Yay they are arriving! Boo you have an issue!
The graphics glitches are caused by faulty video sdram on your board. Top Blade uses a different section of video ram than the other games.
I definitely made sure to program and test every cart before sending them out.
Slot 5/6/7 are empty, but Slot 8 should have Urachacha
Looking at the tracking info, a few more people will receive their packages tomorrow and Wednesday.Really cool to see these boards going out to their new owners. Hopefully some more posts/pictures from others to show them off
I will do another run and build more if there is interest.hi :
Are you still taking orders or was it a closed run?
regards
euphoria
I backed out so maybe you can have my unit.hi :
regards
euphoria
Maybe as a precaution/maintenance the ram should be replaced. Have you noticed any difference between motherboard revisions as far as ram failure?Yay they are arriving! Boo you have an issue!
Yes, like my first system (that I'm actually still looking for) this one also had a leaky battery, but not as bad. It has scratch sound. Is this RAM near the battery area? With my first system, I have bought a few extra RAM chips, but I can't find it or the system right now.Yay they are arriving! Boo you have an issue!
No evidence to support that theory, but perhaps we will be able to answer that as more carts arriveHave you noticed any difference between motherboard revisions as far as ram failure?
That chip itself may be faulty, but reflowing the solder is good place to start. I solder pretty much everything at 750F/400C myself, but not every iron is accurate at temp. With flux it only takes a second to reflow a joint. Best to practice on a junk piece of electronics before something you care about. https://www.youtube.com/watch?v=5uiroWBkdFY -- watch the whole thing, but the part at 2:20 is the technique you need. Any 1.5 to 2mm tip is fine, you don't really need a bevel tip like shown.When I press on the smallest chip it clears up the graphics issues, so maybe just needs to be warmed up so the solder sticks again.
As for Wuly Buly, it plays too fast, so something is wrong. Game 1, with the roaches is fine, but game 2 and 3 (especially 3) are going too fast to actually play. Is this an overlooked protection issue?
I don't recall wuly buly having a speed problem on my end, but I will hook it up later and see what I get. There is no protection chip for wuly buly, so that is not a problem. I have a feeling it might be related to the battery acid problem, which could have effected the nvram used for game settings. If you press both service+test buttons on the motherboard, then press reset, it takes you into the crystal system bios menu. Try resetting the nvram and booting into the game (without turning the power off).3. Any ideas of Wuly Buly? Is it some setting or my bad RAM that makes the game so fast?
I had this one on identical hardware that just needed the V-Ram reflowing:Small one to the left of your bottom chip and below right of your left chip. It's clearly working fine if I give it a tiny amount of pressure.
EDIT: Also, get that battery out ASAP man!
I have one of those irons that lets me set the temp that Voultar recommended (the internals are like his).That chip itself may be faulty, but reflowing the solder is good place to start. I solder pretty much everything at 750F/400C myself, but not every iron is accurate at temp. With flux it only takes a second to reflow a joint. Best to practice on a junk piece of electronics before something you care about. https://www.youtube.com/watch?v=5uiroWBkdFY -- watch the whole thing, but the part at 2:20 is the technique you need. Any 1.5 to 2mm tip is fine, you don't really need a bevel tip like shown.
Hmm, maybe since these caps were so tiny it was easier. OK, I'll practice on something easy, like maybe a TurboDuo re-cap, then hit this up!I set mine around 350-400C.
Got it, put iron on finger, feel it out. Unless you mean another, more precious tip. Nah, I'll stick to the finger!Screw temps on cheap irons. Do it by feel, touch solder wire to the tip and observe how it responds. Not melting well, increase temp. Melting too much and not adhering, lower temp.
Don't overthink things or think there's a magical universal number.
