I've been slowly restoring an original US Monkey Ball, and I've hit a snag with the joystick... I could use some help, as I'm a full-fledged amateur.
TL;DR the original joystick is drifting during gameplay and drifts different amounts as you play. I've tried calibrating it several times in the test menu to no avail.
I'm gonna try to give as much context as I can, in case it helps.
- When I first purchased it, I believe there was a short shaft Sanwa joystick installed with a poorly 3D printed banana. I didn't test much, or recalibrate, but I recall there being a little drift. This joystick was hooked up directly to the JVS IO board via the 26-pin CN7. I removed this joystick.
- The previous owner happened to have an original joystick, banana, and amp board. However, the harness had several wires cut, and the connector was wired wrong.
- I installed the OG joystick and the amp, which was easy because all those wires were untouched. But I had to redo the 26-pin connector. I followed the general Naomi wiring diagram here. Pins 1 and 2 for 5v each. Pins 3 and 9 for 1P V/H VOL. Pins 23 and 24 for ground. I used a pin crimper with Dupont 2.54 mm pins, but for some reason the pins are loose and come out easily. I was able to insert the connector without the pins coming out by doing so gently.
- I fixed the cut wires using WAGOs and made sure the amp board was getting both 5v wires, the grounds and the V/H VOL.
- I recalibrated the joystick in the test menu. I rotated pretty hard and let go a few times. When I let go the values are jittering a little. I tried a few more times with no improvement.
- When I first start playing, the monkey is perfectly still. But, after playing for a few mintues, or when a hard direction change happens, it starts to drift. The amount of drift varies, sometimes a lot, sometimes a little. It can also be horizontal or vertical.
