Calling all Monkey Ball joystick experts!!!
Yeh don’t follow my pic
Its wrong as far as i can see !!!!
I have no idea why this came with a 10 way !
It should be 8 way.
I’m going to follow this info here
https://gamerepair.info/games/45_monkey_ball
Maybe this stick I have was wired bespoke for another cab ..
For exsample - I’m using the Capcom io for now for analoge interface .
So you can just pick the
4 wires with du pont connector wires right off the io.
Or use 8 way and match the pinout to the pannel connectors shown in picture ..
Would it be wired for an Astro/New Astro / Blast City? Maybe?
It should be 8 way.
check pin 1 on player 1
Analoge interface for 5v+ To pin 8 Gnd .
With multi meter .
Then you can’t go wrong ..
H & V
the orange and red wire) is joystick Y position, pin 3
the orange and gray wire is joystick X position and pin 4
the white wire) is GND.
Yellow 5V+
Yeh maybe I will check that out..
It's probably that. In the Astro and the Blast, there's a 10-pin auxiliary connector that doesn't terminate into anything. It's just a passthrough. The other end would have then been wired to the analog input of a JVS to Jamma board.
At least that's how I would have done it.
Cheers for confirming that 👍
I’m making a 10 way blast pass through to the Naomi 8 way
So I don’t need to cut it off, and it will do all three cab types then , ;)
I might as well do that, as wold need to change anyway..
I will do a better
Pic later .
Only just got it going from the jvs io ..
I was using a Capcom jamma io before ..
So took this opertunity to get the correct io connected up.
And have all connections as they should be .
