Ziggy Cheetos Dust
Is there a quick adjustment I can do on the chassis to flip them image? My Raiden Fighters 2 is upside down and I’m not sure that this particular PCB has a switch to rotate it.
if you are careful, you can just unplug the cable and plug it back inThanks for posting that @ekorz. I will have a look tomorrow. Maybe I’ll have to remove the monitor again?
Raiden Fighters 2
Hey if you’re feeling frisky all the switch does is ground this line on these smds. I have no idea what they do but if you have some you could try grounding or lifting the ground.. whichever it isn’t. You know for science!
It could be. It was still screwed to the board when I took the pic. I’ve had to travel for work now but will get stuck into it when I get home.You sure it's not on the solder side? Did you check continuity with a meter?
