Capcom CPS 1.5 to CPS2 Conversions
kuze
Enlightened
ATX
I’ve been working on this for quite some time and finally have an initial release ready:
https://github.com/kuzearcade/CPS15_to_CPS2
Note that most of my real hardware testing has been with The Punisher but numerous full game runs have been done start to finish in MAME. I’m opening this up for community testing and will work out any bugs that turn up.
All CPS 1.5 sets are supported and this was put together fresh from the ground up.
Also @Asure has been using a different method and has some great results here: https://github.com/Asure/CPSconverter
Cheers!
Cool stuff. I was looking over the kabuki decryption, its interesting claude is tracing all code paths to handle the decryption (since code is encrypted and data isn't). Seems like that could also be used as an alternate way to deal with suicided mitchell boards (pang, super pang, etc). Put the decrypted roms on the board then swap the kabuki CPU for a standard Z80.
If i add this, can you test on real hardware?
I don't own the physical machine yet,
but this machine is actually a standard arcade machine with the original ROM size.
The official team simply cleaned up obsolete data to make room for new action modes; I didn't notice any changes to the scenarios.
I think basically all that's needed is to rearrange the code|data offset based on wofj.
I have started to work on this. I don't see any obvious booby trap code in the wofch version at the moment, so maybe it's an easy target.
I don't know what the differences are in URA mode compared to arcade version. I'll see if i can add a selection option to easy choose URA or Original mode.
Hmmm sorry if i'm wrong, but the rom wofch.zip is the cps changer version (home version of the cps1) not a hack. Sfzch is cps changer too (lot are undumped :( ) .If i remember right, Razoola start from sfzch vs sfz cps2 to understand the cps2..... long time ago :D
Daimakaimura in cps2 is a dream (make it with ai but the sound.....héhé)
Yeah we need an universal sound porting tool or something to get the cps1 games into cps2. Alternativelt you can always try and buy a CPS1.5 multi ;)
You remember correctly, sfzch helped in the quest to decode cps2, later Andreas Naive did it fully in 2001.
You've probably been around as long as i was when Thierry made s16emu, Emuviews was king and Mame was good for Galaxian and Donkey kong only hehehe.
I looked up why we need WOFCH but it has an extra mode only on changer, you press start+sel to go to the menu and enter a code to unlock it.
This mode is only on the changer and some home ports. I didn't even know changers exist with Q-Sound lol!
There was some more magic needed, but i am getting there.
WofCH is added to https://github.com/Asure/CPSconverter.
Edit: Sorry i am piggybacking on your topic Kuze, i can move it all into a new one if you want?
(I did not intend to update the Converter anymore after this point.)
Nice one! No need to apologize, happy to share the thread and appreciate the work you’ve been doing. I think it’s great to have all the discussion in one place too. I’ll add your link to the original post also.
On Dino2c rom 03, go to A738 and change 01 to 02 . it turn to ETC version. Japan is 00 but need other offset to change language ..... where is it :D
@kuze
I just had time to try again and tested the most recent versions. For reference, I use a Darksoft CPS2 multi. Unfortunately they still have graphical issues (both: C&D and The Punisher). Notice that pic 1 is how the character selection looks at the beginning, it fixes after choosing a character, as seen in pic 2:
It's important to make clear that the games play fine and they do not crash, only graphical issues are present. No idea about sound glitches since I have never heard the real games in Q-Sound and I play this using mono output, but they sound good to me. Definitely better than my bootleg C&D board.
@Asure
I tested the three roms you have in your repo and in my multi they seem to work correctly, however I'm no expert in any of them.
I have a question though: I noticed that Asure's roms seem to be harder than kuze's, like they start by default in a higher difficulty level. Is that possible, or am I dreaming things? if it's not a dream: is there a way to patch the roms to play by default in a more "medium" difficulty level?
That's interresting, because i had the same feeling, with C&D and the WoF games, they felt 'harder' and i thought i was imagining it.
I need to double check the exact rom i based the game conversion on but i think it was the US version. Maybe 'world' was easier.
I can also let AI dig into it.
What i found more difficult was the number of hits needed to kill an enemy, it mostly ramped it quite fast and only stage 1 or 1.5 felt easy to kill them, but after that it feels more difficultt and i need more punches/kicks.. was that the same for you?
It's not linear like SF2 or Mortal Kombat for example, those do the same damage to each player but the reactions are faster to your moves.
It's correct, it does feel like enemies can absorb more damage in your roms than in kuze's.
I've run out of tokens for this week, but if you have a chance, try and run some of the versions in mame for 1.5 us/world/japan on default, i guess the difficulty differs per country.
@kuze
@Asure
Thanks again for the additional testing @aha2940 - I really appreciate it!
@Bonky has contributed some very helpful patches that resolve a bug causing the error on hardware that you faced, as well as some significant timing improvements.
I'm still doing some further testing, but should have an update available in the next day or so for you to try.
