I used the harness that I got with the original "full size" repro spinners which has an 8-pin JST NH connector going to a pair of 4-pin JST NH connectors. That one worked out of the box with the CPS1 multi; I'm sure I would've noticed if the spinners were wired wrong. I didn't try using the harnesses that came in the box with these spinners as I saw the larger connector had the wrong number of contacts and I knew I had that other harness.
I'm fairly sure wiring the power backwards won't work, you're reverse biasing the LED in one side of the sensor, but having the signal wires swapped will give you exactly the behaviour you're seeing due to how the quadrature encoding works.
