aoiddr
All you need to do is change the byte, this works for both Crazy Taxi and HOTDHello is there a version that runs on type 3 hardware?Code:CTHR: 0x1502E: 0x00 -> 0x01 HOTD: 0x2102E: 0x00 -> 0x01
You need a Hex Editor like HxD available at https://mh-nexus.de/en/hxd/
Then open the file, go to that offset indicated and change the 00 for a 01. Save and load into Chihiro.
I'm trying to do this and am a bit confused also as it's been forever since I've used HxD. I'm not clear on which Offset line relates to "0x1502E" for the Crazy Taxi fix and trying to find "1502" in a search doesn't turn up any results. Would it be possible to get a bit more direction on where the lines are that need to be changed? Thanks.
