Added -r switch to remove files automatically, thank you @mathewbeall for testing
Not sure - but I can tell you it worked fine - i formatted the CF card in win10 - ran the new gcfi with the remove flag, and dropped in my naomi2 - worked perfect.Even if you remove them, won't they just be marked in the directory table as being deleted. (starting with a ? if I remember well.)
This would position the relevant files further in the file allocation table, but maybe it doesn't matter for the protection mechanism?
The directory entry index would change but the physical placement of the files would start on the same cluster since the clusters would have been marked as free.Even if you remove them, won't they just be marked in the directory table as being deleted. (starting with a ? if I remember well.)
The loader file has to have the same name as the one inside the PIC i.e. ABC.BIN.I thought that name was embedded in the security pic code.
So you can make the file wathever you like as long as the security pic code has a reference to the same filename. (And it probably needs to be 3 letters before and 3 after the dot.) Besides that, I doubt there is a benefit in having a 1Gig dimm on chihiro. (Triforce is another story)
yes. it doesn't even need to be from another Chihiro, go here to find known working PC memory: Those of you with 512MB and 1GB DIMM boards...Can I make my 512MB Chihiro a 1GB just by adding another stick of ram from another 512MB Chihiro?
They probably got tired of supplying extra PICs and modified the code to auto add extensionDoesn't matter the game.. If you have a 1GB Chihiro, you need to use the "ABC.1GB" file name... no need to modify PIC or anything else, its how it just works in the firmware. Yes, the Loader File points to the actual game file. -- i was just adding that to the information / directions in case anybody was using a 1GB Chihiro.. even though no games ever appeared to use that unit.
Because the HOTD3 "patched" Type 3 file i got 9 years ago, didn't run on a 512MB ChihiroI still don't see the point why you would need 1Gig in your chihiro dimm. Am I missing something?
