Chihiro/NAOMI/Triforce CF Tools
Thanks. I didn't think it would.
Looks like the search for cheap compatible cards are in order... I'll order a couple from aliexpress and hope they work
Edit: ordered 5 of the 512mb cards here https://www.aliexpress.com/item/4000150162779.html?spm=a2g0n.order_list.0.0.21ef1802bMFjWM
I'll report back in a month or two when I get them :D
Got the 5x CF cards that I ordered today.
Of the 5, 3 have successfully loaded.
This is essentially what I did to all 5 cards
Used the -W flag, formatted to FAT default allocation and ran it again to copy the file. Naturally the thing that changed is the Key ID.
Code:
C:\Naomi\CF\gcfi_1.30>gcfi -W -p -r -s 0x3233 -d D:\ -l ABC.BIN -g MVC2.bin
os version    : 10.0 (19043)
logical drive : D:\
sector size   : 512
removing files: done
physical drive: 2
wiping sectors: done
please eject and reinsert the CF card before formatting it as file system: FAT
C:\Naomi\CF\gcfi_1.30>gcfi -p -r -s 0x3233 -d D:\ -l ABC.BIN -g MVC2.bin
logical drive : D:\
sector size   : 512
physical drive: 2
sector offset : 0x3233
game file     : MVC2.bin
file size     : 143242752 bytes
loader file   : ABC.BIN
output file   : MVC2.BIN
region byte   : 0xff
game crc32    : 0xe834a592
loader crc32  : 0x17cb5a6d
copying file  : MVC2.bin -> D:\MVC2.BIN
region patch  : done
generating xor: done
creating csum : done
What I did notice is the two that appear to not work (just loads a black screen) have a character at the end instead of a number. I'm also not sure if it's case sensitive.
When I run the ataid.exe, it shows as 0x564b and 0x354a, when I try and load these cards, it just doesn't want to work for me (I've tried writing in both upper and lowercase, but still just a black screen)
Here's an example ataid excerpt
Code:
C:\Naomi\CF\gcfi_1.30>ataid.exe -p 3
device    : \\.\PhysicalDrive3
model     : SILICONSYSTEMS INC 512MB
Firmware  : 290-0230
serial    : CD01551075500B1B5J08
sector    : 0x354a
0x00000000: 4a 04 f3 03 00 00 10 00 00 00 00 02 3f 00 0f 00  J...........?...
0x00000010: d0 8c 00 00 44 43 31 30 35 35 30 31 35 37 30 35  ....DC1055015705
0x00000020: 42 30 42 31 4a 35 38 30 01 00 01 00 04 00 39 32  B0B1J580......92
0x00000030: 2d 30 32 30 30 33 49 53 49 4c 4f 43 53 4e 53 59  -02003ISILOCSNSY
0x00000040: 45 54 53 4d 49 20 43 4e 35 20 32 31 42 4d 20 20  ETSMI CN5 21BM
0x00000050: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 01 00                ..
Anybody ever come across this issue before? It's just strange that the other 3x have loaded the game fine, but these two haven't and they're the same brand CF
Can you show us the complete ATAID from one which does not work and one which works ?
These two don't work (i just get black screen no matter one)
Code:
Firmware  : 290-0230
serial    : CF38529889500B17VK03
sector    : 0x564b
0x00000010: d0 8c 00 00 46 43 38 33 32 35 38 39 39 38 30 35  ....FC8325899805
0x00000020: 42 30 37 31 4b 56 33 30 01 00 01 00 04 00 39 32  B071KV30......92
0x00000060: 00 00 00 0f 00 00 00 02 00 00 03 00 f3 03 10 00  ................
0x00000070: 3f 00 d0 8c 0f 00 00 01 d0 8c 0f 00 00 00 07 04  ?...............
0x00000080: 03 00 78 00 78 00 78 00 78 00 00 00 00 00 00 00  ..x.x.x.x.......
0x00000090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0x000000a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0x000000b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0x000000c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0x000000d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0x000000e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0x000000f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0x00000100: 00 00 36 30 32 30 31 30 38 62 00 00 00 00 00 00  ..6020108b......
0x00000110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0x00000120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0x00000130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0x00000140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0x00000150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0x00000160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0x00000170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0x00000180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0x00000190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0x000001a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0x000001b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0x000001c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0x000001d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0x000001e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0x000001f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
Firmware  : 290-0230
sector    : 0x354a
And these three have had a successful load, but it's quite temperamental, it has its moments vs a SanDisk which appear to load each time
Code:
C:\Naomi\CF\gcfi_1.30>ataid.exe -p 2
device    : \\.\PhysicalDrive2
model     : STI Flash 8.0.0
Firmware  : 01/17/07
serial    : STI1Mm9509287152321
sector    : 0x3233
0x00000000: 8a 84 e1 03 00 00 10 00 00 00 00 00 3f 00 0f 00  ............?...
0x00000010: f0 45 00 00 53 20 49 54 4d 31 39 6d 30 35 32 39  .E..S ITM19m0529
0x00000020: 37 38 35 31 33 32 31 32 00 00 00 00 04 00 31 30  78513212......10
0x00000030: 31 2f 2f 37 37 30 54 53 20 49 6c 46 73 61 20 68  1//770TS IlFsa h
0x00000040: 2e 38 2e 30 20 30 20 20 20 20 20 20 20 20 20 20  .8.0 0
0x00000060: 00 00 00 03 00 00 00 02 00 00 03 00 e1 03 10 00  ................
0x00000070: 3f 00 f0 45 0f 00 00 01 f0 45 0f 00 00 00 07 04  ?..E.....E......
0x000000a0: 00 00 00 00 68 70 04 40 00 40 68 70 04 00 00 40  ....hp.@.@hp...@
0x00000100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
model     : STI Flash 7.3.0
Firmware  : 06/16/05
serial    : STI1J93206132215251
sector    : 0x3532
0x00000000: 4a 04 e1 03 00 00 10 00 00 00 00 00 3f 00 0f 00  J...........?...
0x00000010: f0 45 00 00 53 20 49 54 4a 31 33 39 30 32 31 36  .E..S ITJ1390216
0x00000020: 32 33 31 32 32 35 31 35 00 00 00 00 04 00 36 30  23122515......60
0x00000030: 31 2f 2f 36 35 30 54 53 20 49 6c 46 73 61 20 68  1//650TS IlFsa h
0x00000040: 2e 37 2e 33 20 30 20 20 20 20 20 20 20 20 20 20  .7.3 0
Firmware  : 01/17/07
serial    : STI1M26407109181055
sector    : 0x3130
0x00000010: f0 45 00 00 53 20 49 54 4d 31 36 32 30 34 31 37  .E..S ITM1620417
0x00000020: 39 30 38 31 30 31 35 35 00 00 00 00 04 00 31 30  90810155......10
I'm not sure if it's the cards, my dimm (if I did anything wrong? It's a flashed 4.02 from 1.02), my naomi (seems to work perfectly fine with netboot) or just CF loading in general that has a pretty bad success rate - well more so when I go from sandisk to another brand CF card
Thank you for the info. I will take a closer look later today.
I have had great success with: Lexar and Trancend.
yeah I tried both - but nothing..
I bet you if I try it again, it'll work lol - but I've now got 4x cards that behave exactly the same, you power it on, it just black screens. All my tests have been the same bin file so there's consistency, but the only thing consistent I've gotten is SanDisk CF cards seem to be favoured more than anything in my testing
Yeah, I haven't had any issues with CF loading using 512MB SanDisk cards.
@mR_CaESaR
The ones which don't work identify themselves as: SILICONSYSTEMS INC 512MB
The ones which work identify themselves as: STI Flash 7.3.0 and STI Flash 8.0.0
So your cards are in fact different even if they have the same label.
What kind of adapter are you using for the CF cards ?
@mR_CaESaR
I didn't even take notice of that until you just pointed it out.
I've since done more testing and these cards are unstable AF! The 3 cards that loaded yesterday no longer load properly (same bin and different bins, process remains the same, however, I didn't format). It'll go through the boot screen, go into a loading/checking memory loop and then error out with "this game is not acceptable by main board" and when that happens, the naomi doesn't appear to boot any working cards after unless I do an unplug, reseat and then load one of the SanDisk CF's in
The CF solution was supposed to be easy, I didn't realise how finicky and particular this solution is haha.
I'm using a generic USB card reader from ebay and also one I had from many years back. Do you think it could be the way it's written onto the CF card? I would've thought if it's "successfully written", then there'd be no issue unless there's an issue with the compatibility of the card
The original CF solution from SEGA used high quality industrial cards. Sadly now there are a lot of counterfeit CF cards around.
Sorry I meant: What kind of CF interface are you using on your NAOMI DIMM ?
I use CF on my NAOMI2, Triforce and Chihiro with no issues at all.
The most important part to check is that the NAOMI is powered properly. A NAOMI with DIMM uses a lot more power than with a cart.
Ahh sorry, misunderstood.
I'm using this one https://www.arcade-projects.com/threads/sega-naomi-dimm-adapter.20079/
Naomi is definitely powered properly, I can almost replicate the issue all the time after a bad load. Netdimm works perfectly fine. It's the particular cards that causes it to do a bad load and causes a black screen and nothing will work after that - even the sandisk cards. The moment I reseat the dimm and load the sandisk card, it'll boot first go.
What CF interface do you use? Mitsu's ones? Tailsnic's ones or something you made yourself?
Thanks. I've got 5x working SanDisk's and it works all the time no issue. I might try that transcend as a last resort.
I don't need to have the whole Naomi library on hand, I've already got a net dimm setup, I just really wanted to try the cf solution.
That sega cf box would be nice to have :)
Reactions: rtw
Hi guys. So I'm looking to buy a laptop to start making my own CF cards for my own use. I know we need to obtain the 4 digit keys for each card. Would a Dell Latitude D610 notebook with Windows XP PRO work? I will also have a CF adapter.
