After a long development, I'm happy to annouce that the CPS1 Multi is in its final stage. The Multi PCB includes both the B PCB and the Qsound PCB. It's completely compatible with CPS1 and CPS1.5.
As you can see it has both the Option for inserting a C board and just soldering a B-21. For now, it only supports B-21 C Board, preferably those that have a battery and you can write the keys on the go. It has also the connectors for spins and kick connectors that you can find on some C Boards.
Q sound PCB is also supported as you can see and has the regular RCA connectors.
It works with the usual microSD slot and flashes. I should be taking preorders in 2-3 months. Price will be slightly higher than anticipated as it has now the Qsound part integrated.
Is your body ready?
UPDATE 12/12/2022: New Firmware that fixes the Bars on the cave stages of Chiki Chiki Boys. See attach.
Is your body ready?
