What Donor Board to use for the CPS1 Multi![]()
Based on the suggestions here, I spent even more money and bought another A board. The multikit still doesn't work.
Looks better, I'd use that one. The OKI and CPS A-01 look reflowed if not replaced. What doesn't work with that one?How about this board?
I can't run any games. The LCD will say that it's "now playing" but it doesn't work. Some games will be blank. Willow will have this flashing stripe pattern.Looks better, I'd use that one. The OKI and CPS A-01 look reflowed if not replaced. What doesn't work with that one?
What does that A board do with an original B+C?And SF games will have this error.
Plays Street Fighter IIWhat does that A board do with an original B+C?
Thanks for the tips. I haven't pulled the boards apart yet to see what might not be original since it was working.@notsonic https://www.mvs-scans.com/images/6/62/Cps1_a_89626A-4_set1_top.jpg is high res. There's a tantalum cap at CC20 though I think some folks say it's optional. Lots of jumpers that I'm not sure what they do either. Same goes for the surface mounted caps/jumpers. It's hard to see if you have them all. I haven't chased down everything personally -- it seems a bit of a chore trying to undo the previous work honestly -- but here are some schematics you could use: https://pcbjunkie.net/index.php/guides/capcom-cps-cps-1-repair-guide/
Another thing I'd do is add in an actual YM2151 and YM3012, a Z80A, and honestly whatever else is socketed. Then I'd go over all the other sound chips and see if they were installed properly, like that OKI repro for example. Certainly test the 2015 ram they added (looks like it's in a socket too) below the z80.
The resef for sure must be attached, otherwise the b21 won't be programmed and nothing will work.It's working now! For the most recent board I tried, I had left off the QSound and Reset wires because I assumed I wouldn't need them just for testing purposes. It turns out they are needed. Thank you to everyone who helped.
100% agree with you.I think the only lesson to be learned is for this multi, don't get an A board from China.
Well, when you say there is nothing that stands out and then I see that list, I have a small contradiction feelingI wish I knew what exactly the problem is with my other A board. There's nothing that really stands out like those 1.5 boards with half assed audio sections. It does have signs of work/repair though.
- The volume pot is not the usual white one. It's smaller, orange, and it has an orange sticker under it.
- The OKI chip is not branded but it is marked 6295 1998.
- The YM3012 is faded so I can't tell for sure but it does say YM3012.
- The YM2151 is Yamaha branded, made in Japan.
- The Z80 is NEC branded instead of Zilog.
- The 68k is Hitachi, not Motorola.
- The CPS-A-01 looks reworked.
You did the right thing. Got an original A Board and all is good!!!
