stringbean
I was booting up some of the ROM hacks in the encrypted rollup pack and I'm uncertain what is different about them. Does anyone know of what the changes are exactly in all the CPS2 ROM hacks?
ok,Não posso entrar em detalhes extremos agora, mas aqui está a melhor explicação que consigo:
- Desolder a bateria da placa B. Deixe-o parado por um tempo ou curta o componente EXC5 com uma chave de fenda para limpar a chave atualmente armazenada.
- O conjunto de roms que você usará dependerá se você tem ou não os fios de escrita de chave instalados ( https://highscoresave.com/champion-edition-cps2-key-writing-cable/ ).
Formate seu cartão SD para fat32.
Vá aqui primeiro: https://archive.org/download/darksoft
Se você tiver a escrita da chave, obtenha ' Darksoft CPS2 2020-05-24.7z '
Se você não tiver a escrita da chave, obtenha ' Darksoft CPS2 OLD Decrypted.7z '
O que quer que você obtenha, extraia a pasta 'games' e coloque-a na raiz do seu cartão SD. Coloque o cartão no seu CPS2 Multi e divirta-se!
what are the two other download links for, exemplified below:I can't go into extreme detail right now, but here's the best explanation I can manage:
- Desolder the battery from the B board. Either let it sit for a while, or short component EXC5 with a screwdriver to clear out the currently stored key.
- The set of roms you use will depend on whether or not you have key writing wires installed (https://highscoresave.com/champion-edition-cps2-key-writing-cable/).
Format your SD card for fat32.
Go here first: https://archive.org/download/darksoft
If you have key writing, get 'Darksoft CPS2 2020-05-24.7z'
If you don't have key writing, get 'Darksoft CPS2 OLD Decrypted.7z'
Whichever you get, extract the 'games' folder, put that on the root of your SD card. Put the card in your CPS2 Multi and enjoy!
Pretty sure a a and b are seating properly, I've tried with and without the b board housing. All the kit pcbs look to be seated well I'll post some pics. I just reseated again and I also formatted the sd card and loaded the test files. Unfortunately there is no change no text on the lcd.It looks to me like a problem with a bad contact. Are A+B PCBs seating properly? What about the small PCB of the kit that goes where the Program Roms are located? Does it sit properly?
Can you show us a picture where we can see your PCB and the installation? Have you followed the instructions and troubleshooting tips? Like ie using the Verify romset or to try first games without key writing cables, etc.?
Sorry for delayed reply. I tried reseating a couple of more times. Not sure what is going on now but when you press load game it either takes a while before it starts writing or doesn't start at all, it also seems like the voltage is fluctuating more than before. I downloaded the legacy rom pack and have tried both sets with and without the keywriting wires connected.Great news! To me it looks like the small interconecct PCB is not inserted properly on the side of the Multi PCB. Can you check that? What happens if you remove the key writting cables and try to load a game where the file key in the game folder is full of 0xFFFFFFFF
