djanice1980
Been waiting patiently for these kits to come in over at VGP for awhile now.
https://videogameperfection.com/products/cps3-digital-interface/
Sent emails inquiring about them to Matt over there and he let me know that he did not know when more would be coming in.
I went to the creator's (Kenzy) website to see if there was any additional information. I sent emails and tried searching for Kenzy everywhere. (Kenzy come home we miss you!)
https://www.lovegood.dev/2020/07/cps3-qsb-for-cps2digiav.html
Weeks and months went by and I decided that I had 2 options. Either make them or......
wire the CPS3 up manually
(gross).
So.....
I am on like revision 5 at this point and I have spent a small fortune so far (for me anyway). I am setting my sights on Ultra SIMMS next...... Just kidding @Darksoft - this s$@t is a pain and I cannot imagine what kind of work you have had to put in to your projects - nothing but respect.
The good news is that Matt at VGP recently informed me that there may be some new stock coming in soon! I guess this is like when you wash your car and then it decides to rain.
EDIT
Happy New Year everyone!!!
As promised here are the BOM and Gerbers for these PCBs. Do with them as you wish! Please improve upon my work and help the community.
BOM
Settings I used for part 1
Layers : 2
Material : FR-4
PCB Thickness : 0.6 mm (this helps for being able to solder to the chips on the CPS3 - you might be able to get away with 0.8 )
Surface Finish: HASL(with lead)
Half-cut/Castellated holes :Yes (castellated holes is a requirement!)
Tented vias: Yes (helps to cover anything on the backside of this board since it will be placed directly on the CPS3 (prevent shorts)
Settings I used for part 2
Base Material: FR-4
Layers: 2
PCB Thickness: 1.6mm
If you really want to go crazy - do enig finish for both parts
So.....
EDIT
BOM
Mouser #: | Mfr. #: | Desc.: | Order Qty. |
538-15-91-2100 | 15-91-2100 | Headers & Wire Housings Headers & Wire Housings C-GRID 10 CKT BKWY H | 2 |
649-F52R-1A7H1-11020 | F52R-1A7H1-11020 | FFC & FPC Connectors FFC & FPC Connectors F52R-1A7H1-11020-Slider type | 1 |
640-FFC3A20-20-G | FFC3A20-20-G | FFC & FPC Connectors FFC & FPC Connectors 20W, 1mm FFC Con, Vert, H5.5mm, Gold, SMT, T&R | 1 |
710-686620050001 | 686620050001 | FFC / FPC Jumper Cables FFC / FPC Jumper Cables WR-FFC 1.00mm Type 1 20Pin Length 50mm | 1 |
571-2015357-4 | 2015357-4 | RF Cable Assemblies RF Cable Assemblies C/A, UMCC/UMCC, 1.37 OD CABLE, 200MM LON | 1 |
Layers : 2
Material : FR-4
Base Material: FR-4
Layers: 2
