Could someone test the kit for me because I do not know what to do.
Fortunately, I'm bald because I will have torn off my hair.
I just bought an SD card sandisk, I did not find a 4GB, only a 16GB.
Since with the PALG, at the end of the loading i just have a white screen.
With the PALF at the end of the ROM loading i have a purple screen or a pink screen.
On the other hand, the coin counter no longer deliriums.
And I have no more graphic porridge.
I test the kit with 2 A-board and 2 B-board.
I use 3 sd card, the last SD is sandisk 16Go, i come in order a 4Go.
1st b-board is a suicide 93646B-3, the second is a original 93646B-4.
I'm not sure that using a new B-board is really wise
If anyone have an idea,i'm interested.
I was having issues with a blank screen after flashing was complete. One of the problems was of the 4 wires I fitted for the key writing one had no continuity (internal break), after replacing that I still had a blank screen but it had gone from white to black.
Removing the pal chip completely went from blank screen to garbled graphics/sound and so I reprogrammed my Pal G and now all sorted.
So all I can suggest is:
Check continuity of 4 key writing wires
Remove pal chip completely see if there is any significant change
It might be a problem related to the PAL. Can you program them?
Hello,
I can not, I do not have the material for.
In addition I disassembled the KIT again and tested the continuity between the 2 cards and they are full of false contacts and dry soldering. So not at all sure that PAL is involved
I do my tests directly from board to board.
I had only tested the pins on the sockets EPROM .
At this point I prefer to make sure that at the connection level and continuity everything is ok.
I will put pictures.
We will get there, little by little.
the problem is that by dint of disassembling the kit I still broke a pins, after that is not really serious, this kind of problem is easy to adjust.
i just think the problem don't come from my first B-board.
Thanks for your help.
How many pins are broken in total? Are you confident that the wires that you installed are OK?
hi darksoft,
6 pins broken, I am sure of my wires and the connection.
Ditto for continuity everything is ok.
No more fake contact between the boards.
So at the launch of a rom now I have a 1st screen telling me
error ram then after a few seconds a white screen appears and the coin counter works once. photos of screen.
without PALG I just have a black screen.
My SD card is a 16GB sandisk bought today. I ordered a 4GB, from what I read the compatibility of SD can be problematic.
Mo
More information,
depending on the game launched, I have a different screen
green screen or blank screen with inscriptions that I can not read.
and the coin counter that deliriums.
we will see well with the sd of 4GB, I will cross my fingers so that it fixes all my worries.
Hello,
PALG and new pins well received from darksoft and use a SD card sandisk 4Go. I have no more RAM ERROR message or graphic porridge.
But just a blank screen after loading or purple if I restart the candy cab.
I make the shortcut on EXC5 and EXC1 and even on CC1. But nothing works.
Try loading MVC Unlocked and see if it boots.
Hello,
So I did the test with MVC UNLOCKED, green screen after loading.
I tested with the 1st PALG that of the kit,
graphic porridge on some roms, ram error.
With the new PALG no more worries of this type, just a green or white screen after loading.
For some reason the program data is not reaching your B-board. Is the solder on the program Rom pcb all ok?
hello,
I will test all this, but the best will be that I find someone in France or Europe to send the kit and my B-board so that he can test everything.
Hi guys,
Long ago.
I tested the KIt with a new B-board.
A CvM who has the right jumper, a friend gave me another PALG.
The result is the same, after each load I have a message RAM ERR or SCR 1 RAM NG.
3 B-boards and 2 different A-boards for testing.
All the welds sound good to the tester, I use 4 different SD card.
2 sandisk 4G, a sandisk 16G and a samsung 8G.
I use the latest pack of Roms available on the site.
Can someone test the KIT for me if I send it.
Hi guys,
Long ago.
plenty of users in Europe I think, also from France.
If you cannot find anyone close, I could have a look at it if you don't mind shipping to the Netherlands and have some time as I have some travel and holiday coming up :)
Hello PascalP,
Thank you for the offer.
If I can not find anyone closer before the end of the week, I'll send you the KIT.
Thank you again for your help.
Hello everyone,
After health concerns that kept me away from my candy cab way too long, here I am back.
And my Multi cps 2 still does not work.
Same problem with another B-board a MvC this time.
Someone can test me the kit, because there I do not know what to do.
Looking forward to your answer.
cordially
