xodaraP
Legendary
I swapped the SIMMS around today just to see if there was a different error code or anything, and same problem - when loading SF3.3 version A it freezes on 6min 24 seconds. It appears this is the exact point it changes to the final SIMM (85%) to copy the last of the data.Swap your Simms around to see if the error number changes. If not you have a drive issue.
Does anyone know which files on the disc are flashed to the 64mb main program SIMMS and what the offset is? It seems to work if I copy the data using the Darksoft menu, so I'm inclined to try that and see if it works. But I still suspect the motherboard is bad. I've got another disc drive and cable coming to try that and rule it out.
