Customized versions of games for system 2X6
I have a USA dedicated Ridge Racer V head-to-head cabinet if anyone needs stuff checked, tested, or verified.
Discussion Thread:
Taiko Drum Master - Region Hack
Description:
Taiko 11,12,13,14 and 11: Asian Edition and 12: Asian Edition contain regional lockouts based on an injected NVRAM value on the 256 motherboard. Reprogramming the motherboard's NVRAM will work to allow either Asian or Japanese versions to run, but will prevent the others from running. These patches can be applied to the "Asian Edition" games to allow them to run on Japanese/Export/USA region System 256 PCB's, and can be run on the "Japanese" games to allow them to run on ANY region PCB.
File(s):
View attachment System2X6-TDM-NVRAM-Hacks-Xdelta.zip
How to use these files, how to operate to play its role?
I.. THINK you just need to run the xdelta patch that corresponds to what you want against the TEBGAME file in the dongles...
Sorry, it's been a while since i posted these, and I'm a little too tied up to verify, but you could alternately just hexedit the files as indicated in the post...
@andymage can you explain to us what you are trying to do ?
Do you own the physical NM00046 T111004-NA-A dongle ?
@andymage 你能向我们解释一下你想要做什么吗?
您是否拥有实体 NM00046 T111004-NA-A 加密狗?
我在游戏上运行这个游戏!模拟器,当然我还有 Namco 256 街机硬件
I'll be updating these patches when i have a moment with full-dongle patches for the 2X6 collection dumps so no one should have issues using them directly with brizzo's dongle or whatever they want to do with them. I seem to get a bunch of questions on how to use them, and TBH, it's been ages since I've updated them.
<3
BATTLEGEAR3 Tuned is limited to operation in a 246C rack, and it would be interesting if this could be removed.
(RACK ERROR!! is displayed).
I have received brizzo's dongle, when will you update these patches, including
太鼓の達人 11亚洲版Asian version
太鼓の達人 12亚洲版Asian version
太鼓の達人 13
太鼓の達人 14
Battle gear 3 tuned
NM00009 Netchuu! Pro Baseball 2002 This game keeps showing loading and cannot enter the game
NM00019 TE51 DVD0B [Ver.5.1] (DVD-ROM) Even if the correct dongle is paired, all characters cannot be displayed, but the TE52 paired dongle can display all characters.​
  • Like
Reactions: rtw
Hi! :)
I would like to know if someone competent in the field, can replace the quality of the music of the game Sangoku Basara X by the version of qualiter CD soundtrack, because frankly the rate of compression of the quality of the music are really disgusting in the version Namco 246 :thumbdown: and exactly the same on the version Playstation 2 NTSCJ X/
Honestly, did Capcom do this compression crap to avoid paying JASRAC royalties ?:whistling:
Thanks :thumbup:
Discussion Thread:
Time crisis 4 working on standar system 256?
Description:
Time Crisis 4 Japanese and Export versions only boot on a "Super" System 256 chassis which has better specifications (and a sound expansion card) than the more readily available System 256 chassis. This patch can be applied to either the Japanese (TSF1001-NA-A) or Export (TSF1002-NA-A) version of the game to allow it to run on a normal System 256 PCB.
File(s):
View attachment NM00032 TSF100X-NA-A, Ver.A49 (Non Super Hack).zip
Has anyone was lucky patching this? I'm having two issues here:
1. Patch extension is .delta which Delta Patcher does not see, it looks only for .xdelta extension
2. When I change extension I'm having error when patching using Delta Patcher.exe and when I use Online Patcher it spits out corrupted file :/
I was running into the same errors, both with version B and C memory cards and discs. I burned the .isos from the system2x6 directory and both were giving me the similiar issues, even as far as getting me to the 'insert coin' screen, but it only showed that with a black background.
The solution for me was to find the game on a .chd and use chdman extractcd on it to burn the file to a cd-r. Game booted right up with NPY1 version C dongle.
I searched for netchu02c.chd
When I have a moment, I will investigate this… Not entirely clear how the iso could’ve gotten corrupted but maybe there’s something going on.
Just FYI, for Super Dragon Ball Z I had to do the same thing, find a .chd and do extractcd and burn that one instead of the ISO I got from the system2x6 directory
Some images need to be extracted as CD and some as DVD. Make sure not to mix them.
is there a version of chdman that offers extractdvd? I've only seen extractcd. Using extractcd works fine for other dvd files I have extracted. Super DBZ is DVD, Baseball is CD
I think for DVD you need to extract using extractraw
