Customized versions of games for system 2X6
I think for DVD you need to extract using extractraw
Hmmm, interesting. I've done extractcd and burn them at the slowest speed my blank disc allows... 4x for dvd and 16x for cd, all of them have worked fine. It's when I extract the iso from the System2x6 directory that I find issues with the game
What do you mean by extract the ISO ?
I found the NM00009 game.
@defor If I use isobuster on the file: NM00009 NPY1 CD0C (CD-ROM).iso, I do not find a file system.
If I use the image from MAME all is good and I find: RB_ARC and the file: RBA.DAT
Here is some technical differences between the images, test.bin is from MAME.
input file : NM00009 NPY1 CD0C (CD-ROM).iso
buffer size: 8388608 bytes
input file size: 194267136 bytes
found: ofs: 0x00008008 [0x00000008] - Primary Volume Descriptor
System id: PLAYSTATION
Volume id: RB_ARC
Block count: 94857
Block size : 2048
Creation date : 2001-08-21 12:13:48.00
Application id: PLAYSTATION
warning, unknown data block length, disabling directory traverser
found: ofs: 0x00008808 [0x00000808] - Volume Descriptor Set Terminator
number of volume descriptors: 1
ofs: 0x00008008, size: 0x0b93c7f8, data size: 0x00000000, type: 1
input file : test.bin
input file size: 223103664 bytes
found: ofs: 0x00009318 [0x00001318] - Primary Volume Descriptor
Volume id: RB_ARC
Block count: 94857
Block size : 2048
found: ofs: 0x00009c48 [0x00001c48] - Volume Descriptor Set Terminator
ofs: 0x00009318, size: 0x0d4bb798, data size: 0x00000000, type: 1
I did a quick test with isobuster on "NM00031 SC31001-NA-DVD0-A (DVD-ROM).iso" and that is OK. Complete filesystem can be read.
