I have something like this in my Megadrive/Genesis; the crystal is replaced with a DFO module that has the same footprint and is programmed with the two frequencies used by the console. There's then a logic pin that you either drive high or low to select which frequency you want. You can wire that to a simple toggle switch, or drive it from something else, in this case a region switcher tied to the reset button.
You can see there is a row of unpopulated headers on the DFO that you can use to (re)program the chip with other frequencies, 10 and 12 MHz should be doable. You just have to be careful when changing the CPU frequency that the system doesn't get confused and lock up, at least on the Megadrive it halts the 68k CPU when switching.
