earthphoenix
Can you try with a regular BIOS? I doubt is that, but worth a try.windows 10. yes (clustersize 64KBytes). sdhc (samsung evo micosd sdhc I). yes (cart is inserted properly). original games work.
problem (stuck at "please wait..." remains). from that screen i can access the bios menu (a,b,c,start). i never got to the game select menu.
- MV1a
- unibios 3.1 (usa, arcade)
Still the same issue after updating to today’s , 2018-25-2, menu update. I have to power cycle, return to menu, then flash game.Received my kit. All is working well with my MV-1B. Except I can’t seem to get the Right + 1p Start or Up + 1p Start to work. Any ideas?
how are you connecting the Mobo to the controls? Supergun? Jamma harness? (which? How long is it?) Extension? Jamma switcher? Some kind of control adapter/ mapper?Received my kit. All is working well with my MV-1B. Except I can’t seem to get the Right + 1p Start or Up + 1p Start to work. Any ideas?
it does help. Thanks a lot. Well look into it.What has been consistent is the failure to load Windjammers when the rom is assigned to Slot 1. In Slot 1, I had it sit for up to 15 mins in the loading screen with no change. I reset and loaded Windjammers twice, once in Slot 2 and 3 with no issue.
Hope this helps.
Yes, this happens.Just one so far. When The "Press S" screen comes up, if you wait past the guy holding out "5" before you press Start, it simply will not work. Press it before "5", and it works fine.
MV1-FZS / unibios 3.3 / HAS 3.1New version of the menu uploaded!
Darksoft's MultiMVS Latest Firmware and Instructions
This should fix several problems with games not showing up on the list.
REMEMBER!!! Read the instructions! You have to copy the menu in 2 folders! At least for now. In future updates we'll probably change that.
We are working now on the rest of issues.
Here is a video made with the previous menu version.can you shoot a short video of this please?
but it' a good point
