APDWaldo6
when deleting the buff file should I delete the 3 slot files too or does it not make a difference?As I said, clearly a problem reading the directory IMHO. The right procedure to get it back to normal until we fix it isreset backup memory
* power off
* remove microSD
* Remove BUFF file
* Insert microSD again
* Power On
That should make things go back to normal. AFAWK Problem comes from going back to menu.
If you are having problems after using QuickLaunch (games not showing up, or menu not rebooting after hitting EXIT), avoid using it for now please.
