Ok. We've sent you a PM. We will get you fixed up.
Wow, has anyone here ever played Atari 2600 Maze Craze?
have you checked the battery on your motherboard? Has still the proper voltage?OK, posting here from here since this thread is technically the correct one. Here's the issue I've been having:
- The cart always resets to default preferences on boot. Nothing is remembered (preferences, DIP switches, high scores) except for saved games.
- I checked the SD card, the BUF1 file is there (13gkB in size according to Windows 7)
Using unbios 3.3, MV-1C board, HAS supergun, PVM, arcade power supply set to 5.04V
Yea that ^have you checked the battery on your motherboard? Has still the proper voltage?
So, cart preferences are saved on backup memory...do they get overwritten if I play too many games? can this save location be changed somehow in firmware, or is it not possible to save those preferences on the cart itself? how will the AES version work?have you checked the battery on your motherboard? Has still the proper voltage?OK, posting here from here since this thread is technically the correct one. Here's the issue I've been having:
I see. I still can't understand why the cart was made to depend on the backup memory of the board, unless it is 100% necessary with no other possible way? i don't get it...Backup memory can hold the configuration of up to 7 games. When the menu detects that we change a game, it will automatically back up the configuration of the previous game so we dont lose the settings. Same applies for AES.
