Ok, so I got my cart today, but the excitement was short lived because so far I haven't been able to get it to do anything at all. Here's a summary of what I done so far.
Copied the Neo Geo Roll-Up BETA 2 (05-03-201
to a Kingston 16GB Micro SD formatted in Fat32 (when I had problems I also set up an alternative with a Samsung 32GB, but neither card performed differently.
My primary MVS is a UNIBIOS MV-1F that I consolized myself (basically just tapped the RGB lines for running into a Framemeister). It uses an original JAMMA power supply, and has a good battery.
On this system, I get absolutely no output at all. Just a black screen, regardless of if there is an SD card inserted or not. I know there is a setup time involved on the first boot, so I let it sit for a good 10min, but nothing. I know people have had success alternating voltages with this motherboard, so I tried every voltage from 4.70 to 5.25v stepping up by 0.05v each time. Nothing.
I have three MV-1Cs with original BIOS that I got in a lot awhile back I was planning on reselling, but figured they might offer an alternative. These are hooked up with a supergun running off of standard ATX PC powersupply, and through a modified SNES JP21 SCART cable to the framemeister. They do indeed perform differently. They all output this screen with an SD card inserted:
The screen starts out animating a bit, kind of pulsing, then after awhile it stops. The screen is similar with no SD card inserted at all, just a different mess of gibberish. Sometimes, after waiting 2-3 minutes, the screen turns completely white.
Checking the SD Cards in the computer shows no change...the update folder doesn't delete, so I know no firmware update completed, and there's no BUF file generated.
All four systems work perfectly with original carts.
I'm so confused and a little frustrated...is it possible I got a lemon? I don't see any obvious signs of shipping damage, and of course I tried the obvious solution of polishing the contacts with alcohol, but so far I've got nothing. Let me know what else I can try, thanks!
