I am using the stock BIOS currently, I initially started with UniBIOS but switched it early on to simplify troubleshootingPlease make sure that you have this option disabled if you have UNIBIOS
Honestly, without looking further in detail the mobo I can't say more. PSU looks OK, BIOS OK, Was the rechargable battery replaced with a button battery? In that case, some part of the charging circuit must be disabled. Did you do that?Thoughts? Is the MV1FS still problematic with the newer carts? Bad caps maybe?
Understand, I appreciate the assistance thus far. I got the board ~12 or so years ago with the battery already removed. I installed the CR2032 battery + holder about a week ago in prep for the cart since I saw a functional battery was required and I already had some CR2032 battery holders on hand. I followed the JNX guide and de-soldered the 470ohm resistor next to the battery. Confirmed battery was functional (time saved, etc) and played ~4-5 hours of MVS prior to getting the cart.Honestly, without looking further in detail the mobo I can't say more. PSU looks OK, BIOS OK, Was the rechargable battery replaced with a button battery? In that case, some part of the charging circuit must be disabled. Did you do that?
At this point, do you have another mobo where you could test it, maybe?
PLMK.
I think that's actually an mv1b in that case. It's folded over using flex cables; unless something changed in the past year or 2.I'm using a consolized MV1FZ with Unibios 4.0 and a SanDisk Ultra 32 GB microSDHC. I haven't checked the power how would I do that?
Thank you, I will have a look at the Timeharvest mv1c. I've been looking at the NEO-BUF chip and if I can get one think I may try to add it at some point. I've done some modifications on other consoles in the past so if I can do it ill post my results.I think that's actually an mv1b in that case. It's folded over using flex cables; unless something changed in the past year or 2.
I don't think any multi carts work well with that consolized setup.
I have the NeoSD (not pro) and the DarkSoft MultiMVS and both exhibit the behavior you are showing on that console.
I have 2 of that console and I've tried the beefiest/best power supplies I could find. No luck. They are both in storage now.
Regular carts work fine. The 161 in 1 works fine.
It has been suggested that the missing NEO-BUF is the cause but I don't think anyone has actually added the chip back and then reported the results. Would be good to know.
If you are looking for a consolized MVS that won't break the bank and works fine with your cart you can try looking into the timeharvest mv1c based CMVS.
If you want something that looks like an AES you can try finding a used Omega CMVS. I don't think they are being made anymore. I like mine. It works well.
I'm sure we can also help get you setup with a supergun if you are interested in going that route.
No problem.Thank you, I will have a look at the Timeharvest mv1c. I've been looking at the NEO-BUF chip and if I can get one think I may try to add it at some point. I've done some modifications on other consoles in the past so if I can do it ill post my results.
It happened to me too on MV-1FZ with original bios.When playing Metal Slug certain audio effects like music suddenly disappear.
According to this source: http://www.hardmvs.fr/html/MV-1FZ.htmIt happened to me too on MV-1FZ with original bios.
I am sincerely sorry to have to contradict an authority such as you, this information that comes from the official manual (which is why it is often mentioned) is false (errors in manuals happen). I think there are people much more competent than me who will be able to take measurements to verify. I think we are well below 7 amps. That said, I did my tests on an AxunWorks supergun, I don't think there is a lack of power on this product.According to this source: http://www.hardmvs.fr/html/MV-1FZ.htm
"The only differences between the MV-1A and the MV-1FZ are the amperages, The MV-1A takes +5V 3A, and the MV-1FZ takes +5V 7A and the socketed BIOS is closer to the Jamma connector on the MV-1A"
MV-1FZ needs more Amps apparently.
Of course, nothing against what you are saying and yes, mistakes in manuals happen more often than we think. Let's have a look and find the culprit of this.I am sincerely sorry to have to contradict an authority such as you, this information that comes from the official manual (which is why it is often mentioned) is false (errors in manuals happen). I think there are people much more competent than me who will be able to take measurements to verify. I think we are well below 7 amps. That said, I did my tests on an AxunWorks supergun, I don't think there is a lack of power on this product.
Anyway I will continue my tests.
Which axunworks supergun do you have?I am sincerely sorry to have to contradict an authority such as you, this information that comes from the official manual (which is why it is often mentioned) is false (errors in manuals happen). I think there are people much more competent than me who will be able to take measurements to verify. I think we are well below 7 amps. That said, I did my tests on an AxunWorks supergun, I don't think there is a lack of power on this product.
This one → https://www.axunworks.com/product-p125502.htmlWhich axunworks supergun do you have?
That's the big boy! I think it's very cool.
