I will send you a PM Shortly.So should I do anything or is my cart working “correctly” given I’m using a 4 slot?
Happy Easter.So should I do anything or is my cart working “correctly” given I’m using a 4 slot?
I have an MV4Happy Easter.So should I do anything or is my cart working “correctly” given I’m using a 4 slot?
Which model 4-slot is yours?
That's the same model I have and I don't have any issues. Got some ideas. You will have a PM incoming.I have an MV4
I've documented these glitches with video too.I've never seen glitches like these. Must be something else going on here. The glitches I mean are 3 or 4 of these lines randomly showing up.All,
Just got the cart... and I have a 4 slot MVS (full arcade game) with no mods (original bios). I know that problems with the 4 slot boards are mentioned but I thought they related to game switching or other things.
Please see the glitches I'm getting in the video below. I do not believe this relates to the contacts as they go away on certain screens and I have cleaned this motherboard such that MVS carts work perfectly pretty much the first time every slot. Can anyone please advise what my issue might be?
Please link to the post where you reported that. Which mobo where you using?I've documented these glitches with video too.
Please elaborate. I have a MV-1A here and works flawless.Not sure if it's been noted but I think the MV-1A has the same voltage issue as the MV-1F/FS.
Just put the latest firmware on, can confirm the white noise lines dancing all over the screen are exactly the same as before. Big red 4 slot.Please link to the post where you reported that. Which mobo where you using?I've documented these glitches with video too.
Thanks for info. Please let me know the exact model of your 4 slot.Big red 4 slot.
The Roll Up that you tested with does not have the latest menu update, please update and retest if that is the version you used to test with. I will have an updated Roll-Up ready soon, with the latest menu.I'm using the latest roll up pack downloaded off the sticky on March 30th.
I posted this before same as Aurich:Please elaborate. I have a MV-1A here and works flawless.Not sure if it's been noted but I think the MV-1A has the same voltage issue as the MV-1F/FS.
There is a new menu update as of April 2 and a new roll up pack as well.I just kind of parked it waiting for an update.
I formatted my SD card, put on the new Smokemonster base pack and loaded it up. The glitching is greatly reduced but still have a tiny bit. What did you change that might have reduced the glitching?There is a new menu update as of April 2 and a new roll up pack as well.I just kind of parked it waiting for an update.
Are you sure you also updated to the latest Firmware? (so not just the menu)I formatted my SD card, put on the new Smokemonster base pack and loaded it up. The glitching is greatly reduced but still have a tiny bit. What did you change that might have reduced the glitching?
