jmandmc
- Joined
- Oct 23, 2016
- Messages
- 43
- Reaction score
- 12
I'm in agreement here. Since the AES saves to SD, I don't see why saving to SD for MVS isn't possible, or beneficial. In my case, since getting this cart, my 4 slot only has the single cart in it, and my battery port was damaged. I have to watch it go to the default settings each time. With saving to the SD card, I would avoid this, and like Michaelm said, you can then save to backup RAM as a redundancy for those who have a working battery.I do think @aha2940 has a valid point.
If it could behave on the MVS like on the AES by
1-copying the settings to the SD on change and subsequently saving them to the Backup RAM for usage
2-and copying the settings to the Backup RAM on boot for usage
It will have 2 nice advantages:
1-One would immediately be alarmed in having to change the battery when the settings do not match what is saved on the SD (The Multi cart could even put a message onscreen stating this)
2-In case of the above the settings are still maintained and after swapping in a new battery you don't have to redo your preferred settings.
