<< ...PSU digital ground... >>
- You mean the GND ? So inside the PSU, the GND is hooked to the earth ? Ok, didn't know that. I'm a noob in electronics haha. But I never have seen any Jamma loom having an earth hooked to the GND. Am I right ? Even on the New Astro the Jamma loom don't have any Earth...
Maybe the Ponys shema shows some bridge connections there but does it mean that both GND and Earth should be bridged with a soldier gun at that point of the Jamma loom on a Pony ? Maybe it only means that both are connected at the origine inside the PSU as you said. I thought that the earth wire going to ''B'' posi. of the jamma looms was only there as a convenience to get the wire across easily and rely the rest of the harness then go to the CP.
<< ... you could try using an AC cable for the whole cab without earth ground... >>
- Does it mean that I can unhook from the cab earth terminal lug both earth wires coming from the main AC cable and the PSU without suffering from any damages ? Btw, in Switzerland we have three wires inside an AC cable as a blue, a brown and a yellow/green (earth). So if you confirm I'll disconnect the earth wire from the main AC cable and the PSU then I'll try that way.
<< ...paint would need to be super thick and well coated for the screw teeth on the binding post to not cut through it. >>
- That's right, I forgot the binding post. So I guess this topic is resolved
<< ...But in my experience it's much like the AC filter where it's just the frame of the transformer that's grounded and it doesn't really have an impact on anything. >>
- So I can hook an earth ring terminal to one of the screw holding the leg of the transformer to check right ? Btw, I can't see any place designed to hook an earth wire on this transformer. Here is a similar model :
https://www.toyozumi.co.jp/products/ad21/pdfs/AD21-200A2.pdf
