Error 24: Gdrom not working (in this case it's CFCARD?!)
Mrhide
Legendary
Montréal, Canada
When you think that you are done and everything is done and working, you make a move and boum :
- I traded my Outrun2 as part of a trade for a mystery game ( stay tune ~ 2 weeks!)
- To make it "bullerproof", I had bought a Cfcard and reader to set it up like my 4 wangan but never got to it
- a day before the trade, I make the card, stick it in, change the jumper, follow the procedure, and I get this:
Not wanting to break the chihiro before the trade, I take another chihiro from a Wangan, put the outrun 2 SP cfcard I made and sure enough, it works and the new owner comes, sees it all working, is happy and leaves with the game.
"must be a bug in the dimm module" I thought and "I have spares so it will be an easy fix".
Well it's not.
I swap with another top board, same results.
I swap this board, same result!
I swapped the 2 ribbon cables and same error 24: GD-ROM is not found result :(
if I change the jumper to network and send a game, everything is good... which I don't really want to do with my wangan... I had the 4 starting in sync with the cf cards!
Anyone with hints / ideas on what could be the issue now?!
thanks.
/me mad
/me go take a break now
What is the min required version for cf boot? I should know… ill check tomorrow morning
Eh boy do i feel dumb.
It is the first thing i set up to do yesterday … and my pi didn’t work… which didn’t help my blinding rage!
This morning i looked at it and figured out i played with it and didn’t plugged it right: the pins of the hat were one row too much on the left. I moved it and voila:
Sure enough
Once done
Thanks for pointing it out @twistedsymphony!
