Telpherion
Sure, any vector edition program should work: autocad, Illustrator, Gimp, Corel, etcI should be able to create case models like this using autocad, correct?
I expect to do for NBA Jam and Mortal Kombat 2 (same board I think) shortly, because I have both of them.I have had a few of these cases made and I really like them.
I was wondering, though, if anyone had case designs for a few boards that I would like to put in cases:
NBA Jam TE (with sound board)
Gradius III
R-Type II
Gradius III
R-Type II
Thats a short A-board, it has the same footprint as the Dash A-board... Long A-board is the oddball/different.So the entire SFII board (the A board on the bottom of the stack) is 24cm x 30cm (not including the jamma connector)
If I measure the distance from the center of the holes on the edges its 23cm x 29cm
I was thinking in some kind of hang on the boards inside the cabinet, and being able to exchange quickly games with these cases. So inside the cabinet, on one side put 4 clips or something like that, so you can just hang the board there and connect the jamma harness. They are all the same size in all boards and are centered.@Telpherion Just a quick question : what's the purpose of these 4 square holes in every bottom plate ?
Where is Australia did you get these cut mate?Got the TMNT and Simpsons Plexi's from this repository cut on the weekend. Also got a shipment of standoffs, spacers and washers off Aliexpress (still waiting on rubber feet and hex screws). I mounted the CPS-1 multi properly this time, for reference the 6 front screws on the "A-Board" are 45mm and the ones on the "B-Board" are 25mm.
Also, using 8mm spacers for the bottom is really tidy but I had to remove the bottom plate on my Sentinel Supergun for the TMNT and Simpsons case to fit the Jamma connector. The CPS-1 seemed to handle it ok because the JAMMA edge is closer to the end of the arcylic.
Also, the plastics place messed up and forgot two of the letter "a" on the TMNT case (Teenage Mut nt Ninj Turtles), they're going to fix it and re-cut it though. Thanks for the hookup again @Telpherion
anyone have a working Ali link to the plastic feet in M3?Thanks!My plan is to continue adding games to the repo, I have a lot of boards that still need one. I've been very bussy this last weeks, but will continue with this ASAP. Just enjoy the cases and post pictures to see the results
For CPS1 I plan to do a lot of games soon.
I have on the repo a case for M107 and other for Air Assault. I think should be almost the same for M92. I have Ninja Baseball, Gunforce and Thunder Blaster, so I plan to add those to the repo as soon as I have a little free time.
For Killer Instinc:
The Male/Female standoff for the top is 40mm long.
Te Male/Male standoff for the bottom is 8mm long.
And this is where I bought the parts:
Female/Female Standoff
aliexpress.com/item/3286996905…042311.0.0.27424c4dhjdhx2
Male/Female Standoff
aliexpress.com/item/3287093818…042311.0.0.27424c4dhjdhx2
Screws
aliexpress.com/item/3280359383…042311.0.0.27424c4dTbgLfm
Legs
aliexpress.com/item/3292119885…042311.0.0.27424c4dTbgLfm
Separators
aliexpress.com/item/3288825773…042311.0.0.27424c4du0UCQt
