So I am assuming that the Jammifier https://irkenlabs.com/jammafier/introduction does not count as the HAS, so it would be the Supergun in this case even though it is just to make jamma work on my jVS cab?
@RGB I am not able to see the kick harness input as per the blue/green box on the example when looking at the cables.
This trick isn't necessary for your HAS version, there are DIP switches underneath the HAS, check if P1B6 and P2B6 are ON, they probably aren't because I leave them OFF by default.I''ve tried holding 2 punch buttons+start and pushing the button 6 times for HK but it doesn't activate on neither my undamned converter or your sega saturn. Is there a dipswitch setting im missing on the harness?
PMed.Yep it works I just enabled it on the harness and it works.
If you don't mind me asking what does the big row of dipswitches do on the back of the has unit?
