You don't have to take the board out each time, but it's not like a "normal" flash cart (i.e. an everdrive) where you quickly load a rom from the SD.Question - so I have been trying to follow this thread.. and understand how it works - is it SD Card based? I heard something about having to flash the cart.. so each time I want to change a game do I have to take the board out and flash it first or can they be all loaded and selected like a normal multicart?
http://www.saveyourgames.it/index.php?route=product/product&product_id=95Thats a little better explanation.. Thanks.. whats the cost? I cant seem to find it in this thread.
Any idea when?It will be available again from here:
http://www.saveyourgames.it/index.php?route=product/product&path=72&product_id=95
Price is also there.
somewere on the forum it was posted that will move quickly after the firmware update for the MVS is done (as that will also impact the AES' save feature)I haven't been around for a while ... Any news on AES version???
Thanks for spoonfeeding. Just so much backlog to read through, haven't checked up here for a while. Thank you tho.somewere on the forum it was posted that will move quickly after the firmware update for the MVS is done (as that will also impact the AES' save feature)I haven't been around for a while ... Any news on AES version???
thx my manthis should offer enough reading to keep you busy![]()
Darksoft's MultiMVS Latest Firmware, Menu and Instructions
Super freaking cool!looks like the fix for the voltage issue is ready. I'll post about it as soon as other testers can confirm that it fixed the issue 100%. Finally!
Currently the solution to the problem with voltage requires a small modifciation on the cart, but most probably we'll manage to avoid that with a simple FPGA firm update. That's why it's taking longer to release the info....looks like the fix for the voltage issue is ready. I'll post about it as soon as other testers can confirm that it fixed the issue 100%. Finally!
In the rare event firmware update won't be enough and a hardware mod will be mandatory, what is your plan B?Currently the solution to the problem with voltage requires a small modifciation on the cart, but most probably we'll manage to avoid that with a simple FPGA firm update. That's why it's taking longer to release the info....
