war3zlod3r
What about full harnesses for Astro or Impress?
Not at this time. The astro had so many different PSUs associated with it I would really need to make an harness for each version made.What about full harnesses for Astro or Impress?
you can post here or shoot me a PM, regardless I'll take a lookNeed to check if you have this harness for the blast. I bought a blast CP with a wiring harness where the AuX port is not compatible with the CP interface port on the blast itself.
I'll take photos tonight.
where did you get the Neutrik connector or did it come with the panel?Hey thanks @Lemony Vengeance for the Brook UD pass through harness worked out great and could use another one at some point for my Namco Noir.![]()
focus attack has em, just off the top of my head:where did you get the Neutrik connector or did it come with the panel?
what what whatThe mad scientist that is Lemony does it again!!! Do you see this!! Vewlix 1/2P harnesses with built in 20 pin header for Brooks boards. So JVS/Console/PC all in one with the deathgrip v1. (Multi button board, ex. 1,2, start = home on consoles) So no swapping cables, no sub panels just a stock Vewlix with dope ass internals. I like to keep my cabs looking like they came straight out of the arcade.![]()
This is a pass through, so yes, you can add my solution and avoid cable swappingwhat what what
@Lemony Vengeance does this mean I could set up a brooks and jvs io or fast io at the same with without having to swap? I've been looking for something like that.
I actually have a 2 brooks boards, the arthrimus, and a regular/fast io. Was wondering how I could string 2-3 of those together and have set up at the same time. Is this it?
https://arthrimus.com/product/vewlix-console-i-o-v2/
. even with the original IO boards.Holy moly. Is it possible to daisy chain 2-3 of them?This is a pass through, so yes, you can add my solution and avoid cable swapping. even with the original IO boards.
I'm not sure why, and honestly it would need to be tested, but conceptually yes.Holy moly. Is it possible to daisy chain 2-3 of them?
