should i buy the connector here? or do you know a better place to get it? maybe someone sells them with .110 quick disconnects amazon.com/dp/B006ZPH71Y/ref=cm_sw_r_cp_api_vq8FBb72NPJ2Z
this is what i found when searching rs online
alliedelec.com/te-connectivity-172334-1/70980851/
^those are the wrong connectors... they wont work...
here is everything you need:
buy 1 of these:
https://www.digikey.com/product-detail/en/te-connectivity-amp-connectors/176279-1/A106907-ND/2328021
buy 10 or more these:
https://www.digikey.com/product-det...-amp-connectors/175151-1/A107106CT-ND/3488667
if you need wire buy 22 AWG:
https://www.amazon.com/dp/B00B4ZQ3L0
for the quick disconnects buy these:
https://www.focusattack.com/110-2-8...ated-quick-disconnect-terminal-approx-100pcs/
and these:
https://www.focusattack.com/nylon-110-quick-connector-insulation-sleeve-approx-100pcs/
Alternatively Focus-attack sells wires pre-crimped with quick disconnects:
https://www.focusattack.com/16pc-22-awg-wire-with-110-quick-disconnect/
your panel also has incorrect buttons, you should be using these:
https://www.focusattack.com/pushbuttons/popular-brands/sanwa/30mm/
your panel also has incorrect joysticks, you should be using these:
https://www.focusattack.com/joysticks/popular-brands/sanwa/jlf-series/
if you don't own a crimper buy this:
https://www.amazon.com/dp/B002TKG11G
or this:
https://www.amazon.com/dp/B002L6HJ8W\
You should be connecting this new harness into this connector:
and you should be wiring it based on this pinout:
^note that the "kick connector" only has 10 pins, just pretend there is another row of pins on the bottom that you don't use.
it looks like whoever owned that cab and installed the incorrect joysticks also mucked up the joystick wiring... PLEASE fix this the right way, and put back the analog and Maple Bus wiring that you removed... make this cab better don't dig the hole deeper.
